failsafe engine light
Old Jul 24, 2018 | 10:54 AM
firemist's Avatar
Default failsafe engine light
2001 XJB Jag - got new tires and new brakes on the front - never use cruise control, yet am not getting a 'failsafe engine' warning with orange light - any ideas?
Old Jul 24, 2018 | 11:55 AM
CharlzO's Avatar
the Brake Pedal switch is a very common culprit. If you can pull the switch off - takes I think an 8mm and a 10? on the nut and bolt on the pedal, and it slides out from there, takes about 5 minutes to remove it. Spray it down with WD40, or even electronics parts cleaner (non-residue), and see if it makes it better at all. In my case, it solved it temporarily, and replacement is simple enough afterwards, if that's what the cause is. I hardly use the cruise myself, but since it's the pedal switch that's a likely cause, and that gets a lot more action, it's worth a shot to test.
Old Jul 24, 2018 | 12:02 PM
firemist's Avatar
will try it for sure. the switch is on the pedal?
Old Jul 24, 2018 | 01:04 PM
CharlzO's Avatar
Yes, it's up near the top of the brake pedal itself. Some people have just wrapped towels around it and sprayed it while on the car, but it can also be taken off easily enough
ReluctantMechanic
Nov 13, 2016 02:48 AM
Bumbazor
Oct 12, 2016 06:49 AM
geewilicurs
Oct 11, 2016 12:00 PM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
Mar 29, 2007 09:00 PM
