False Engine Temp Reading on 1999 XJR
Old Mar 25, 2009 | 02:45 AM
warrickUK's Avatar
Default False Engine Temp Reading on 1999 XJR
Hi everyone, my engine temp gauge only seems to read correct up to half way then stops. The engine overheated recently, the electric fans were not activated and the gauge was still reading 'normal'.
I've changed the engine temperature sender switch, to no avail.
As some of you are aware this malfunction has probably cost me a head gasket job recently...I don't want to do it again and I hope that if someone can tell me what to do here it'll save someone else a head gasket job!!!!
Cheers All.
Old Sep 3, 2010 | 10:33 AM
johnleavitt's Avatar
where was the sending unit...
Old Sep 3, 2010 | 12:21 PM
warrickUK's Avatar
Hello John, sending unit is at the thermostat housing.
johanasu
Sep 3, 2015 12:39 PM
casepie
Aug 30, 2015 09:49 PM
Newsguy
Aug 30, 2015 11:27 AM
Andrew McVey
16
Aug 27, 2015 07:21 PM
souldoubt
Aug 25, 2015 08:15 PM
