False rear light warning
Old Sep 20, 2009 | 06:52 PM
poboyblues's Avatar
What year is the car? If it's a 2003 or earlier, check your battery. If your battery has low voltage/amps during cranking that will turn on that warning light, and also possibly ABS, DSC not available, and several others. They can occur individually or altogether. If your bulbs are good, don't mess with them.
Old Sep 20, 2009 | 07:47 PM
wazari's Avatar
As poboyblues mentioned it could be a low battery, however if its the bulb failure message you are getting intermittingly it could be the bulbs. I have seen this many times at the dealership. If you are using aftermarket bulbs make sure you are using the proper Euro spec bulbs in the green packages if they are Sylvania bulbs for example instead of the domestic orange package bulbs. Although they will fit in the socket, the wattage draw will be different triggering a bulb failure message because the draw is too low. I have seen this many times.
Old Sep 20, 2009 | 09:17 PM
poboyblues's Avatar
Good one, wazari. The bulbs with the gold or bronze colored bases don't work well, either. Silver base is your best bet. Jag bulbs work best, IMO.
99xk8guy
Sep 29, 2025 10:51 PM
D.K
Dec 10, 2023 02:05 AM
jdzubas
Oct 4, 2015 09:14 AM
King Charles
Sep 3, 2015 12:40 AM
OkieTim
Sep 2, 2015 12:48 PM
