Feul leak = high trims?
Old Oct 4, 2014 | 06:27 AM
L80ous's Avatar
Default Fuel leak = high trims?
Today I have a fuel leak on both pipes about 15cm's after the fuel pump and filter going towards the engine. Basically corroded and while the engines running each pipe drips once every couple of seconds, so quite a good leak.
Question is I also have high fuel trims which I have all but given up trying to find, I have had several garages over several hours investigate for intake leaks etc. Could a fuel leak on the pipes after the pump cause high fuel trims.
Was just wondering and hoping this has always been my problem.
Old Oct 4, 2014 | 06:51 AM
RJ237's Avatar
A fuel leak will not cause high trims.
Rivguy
Dec 4, 2020 07:55 AM
Booskisjag
May 5, 2016 09:38 AM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
