Finally its alive...
Old Sep 20, 2011 | 07:29 PM
XJRJeff's Avatar
Default Finally its alive...
I have finally finished my 99 VDP. I put the finishing touches on it last week. Filled it with all the essential fluids, I turned it over several times with the fuel injection relay and fuel pump relay disconnected and it sounded very good. I was able to clear almost all the codes with my scan tool. I then put the relays back in it and turned it over again. It took a couple tries until the fuel got up to the front. But once it had fuel it purred to life. The engine sounds very good. I had to go get a new coolant level sensor and that took care of the last lingering code I had left. Now the only other problem I have is a couple of minor oil leaks at the valve cover. It is leaking right where the timing chain cover meets the head. I am guessing that I did not get enough sealant there at this point when I put the valve covers on. If anyone has any suggestions on a good method to get a real good seal I would be grateful. I really do not want to have to keep taking the valve covers off and on. I was thinking that there may be a crack in the valve cover, I am going to take a good look at it next time I have it off. Other than that, that car is running great and I am loving driving it again. It was definitely worth the hard work of replacing the engine to put this baby back on the road again.
Attached Thumbnails Finally its alive...-2011-09-14-16.57.08.jpg   Finally its alive...-2011-09-14-17.25.16.jpg   Finally its alive...-2011-09-15-21.24.23.jpg   Finally its alive...-2011-09-15-21.24.37.jpg   Finally its alive...-2011-09-17-12.39.11.jpg
Old Sep 20, 2011 | 09:17 PM
aholbro1's Avatar
Sweet! Congrats on getting her back up.
(Looks like mine....only longer...newer..)
Old Sep 20, 2011 | 11:07 PM
northerncat's Avatar
Thumbs up
congratulations on getting her back up, looks good
Old Sep 21, 2011 | 03:21 AM
Cadillac's Avatar
Nice job, happy safe driving
jimforrest (uk)
Feb 28, 2019 06:42 PM
rhemler
Oct 4, 2015 05:37 PM
baskervillema
Oct 1, 2015 06:43 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
Pontsu
Oct 1, 2015 09:56 AM
