First start in 10 years
Old May 2, 2024 | 05:47 PM
03_jaaag's Avatar
Default First start in 10 years
How’s she sounding? I put 1 tbsp marvel mystery oil in each cylinder. tested both pumps prior and fired right up. was the MMO the reason it fired up? because it stalled out i’m guessing to no gas. I put 5l premium gas in the tank after cleaning it and replacing pumps.
File Type: mov
File Type: mov
Old May 2, 2024 | 06:16 PM
RandyS's Avatar
The MMO probably helped the cylinder compression to the point that it compensated
for the possible bad/old gas. Check the Shrader valve to see if your pump is providing
adequate pressure. It is good you are replacing the pumps and removing the old fuel.
gtjoey
39
Aug 30, 2016 06:02 PM
Fezz
Nov 30, 2013 05:00 PM
270weatherby
Oct 12, 2011 06:17 PM
outsidenote
XJ40 ( XJ81 )
Apr 28, 2011 11:27 AM
