Frequent Blowouts
Old Feb 24, 2009 | 11:40 AM
Brutal's Avatar
You should be at least running 35psi if not higher. The lower the psi the more the tire gets pinched on potholes cause it gives too much. Will be a harder ride but you like the look and thats a trade off. You may even want to go to max rec. Psi on sidewall. This is full load rating but with rubber band tires and a heavy car it doesnt take much to cause damage.
ricwel
Jun 23, 2023 05:14 PM
JCam
Oct 23, 2016 08:27 PM
Lord_Rowan
Oct 1, 2015 01:45 AM
bydand
Sep 27, 2015 01:18 PM
