Front brake "clonk" noise
Old Nov 6, 2013 | 04:59 PM
Blue_XJ8's Avatar
Default Front brake "clonk" noise
Greetings all,
Better weather conditions in TX (below 100 degrees that is) means time to list work to be done on the cat :-) You might see a few threads of mine coming up soon.
So, as the titles says, when I go in reverse (out of the garage, parking spot, etc.) and brake to an evenutal stop, I get a loud "CLONK" noise from the front wheels (possibly front right one) and in my opinion is from front brakes.
Background info. I replaced the front rotors and pads myself some ~5k miles ago. Which may very well be part of the problem :-( I do not recall having such issue before replacing. Problem is that I can't recall if I had such noise after replacing them but before I got my steering rack replaced and front shocks replaced... Anyway, one thing I do remember is that I didn't feel entirely comfortable with the re-fitting of the caliper anti-rattling "spring" (not new one, re-used the one there).
I am about to replace back rotors and pads, and while doing that I intend to go back and look at front brakes. Any suggestions welcome.
Old Nov 7, 2013 | 12:31 PM
Sean B's Avatar
can you make a video? there's a number of things that could cause this.
Sounds like a few things require checking too, following the front end work done. Have you access to a ramp? Have you thought about front subframe mounts and engine mounts?
We need more info!
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
James007
Oct 3, 2015 03:29 PM
KarimPA
Sep 12, 2015 08:15 AM
James007
Sep 6, 2015 06:47 PM
