Front discs and Oil Change done
Old Jul 8, 2013 | 12:46 AM
MooSSe's Avatar
Default Front discs and Oil Change done
Whew, that was an experience. I just replaced both front rotors and pads, and while I had the car jacked up I did an oil/filter change.
Went with ceramic pads. Stops the car quite well. had an oil leak due to the old filter being extreamly loose. I made sure the new filter was tight.
I purchased back rotors and pads, but when I pulled the tires and looked at them, they hardly appear worn at all. The Jag has 64K miles on it and the back brake discs and pads look almost unused. No dust on the dust shields at all. I had to scrub the front shields to get them shiny silver again.
Anyway, I went ahead and left the backs alone and will return the rotors and pads.
Is there a brake front/back distribution block that may need to be looked at to see if the back brakes are even being used? The parking brake works good, so maybe that's all it is being used for.
Thanks for all the great advice I've been getting off this forum folks.
Old Jul 8, 2013 | 08:40 AM
John Tarantula's Avatar
On some cars the parking brake is done with a drum / shoe inside the discs / rotors, not by the discs themselves? haven't had my Jag long enough yet to see if this is the case here.
Old Jul 8, 2013 | 10:32 AM
Jhartz's Avatar
It is. Slots for adjusting parking brake in rear rotors; also some slack can be taken out of cable - a source of poor parking brake and an annoying rattle.
kelliott
May 31, 2022 05:26 PM
tberg
Sep 7, 2015 07:32 AM
David Thompson
Sep 3, 2015 07:48 PM
pnwrs2000
Sep 3, 2015 11:55 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
