Front Hub Spring Pin - MJA1845AD
Old Aug 28, 2017 | 07:33 PM
Amphicar770's Avatar
Default Front Hub Spring Pin - MJA1845AD
Is this thing made of gold? $30 dollars for what looks like a $2 dollar part. Is there a substitute?
https://www.terrysjag.com/product/MJA1845AD.html
Old Aug 28, 2017 | 08:16 PM
Addicted2boost's Avatar
Extra long cotter pin or 2 short ones.
Old Aug 28, 2017 | 08:41 PM
motorcarman's Avatar
Avoid getting a steel cotter pin too close to the sensor. You don't want to disrupt the toothed wheel segment spacing or damaging the sensor itself.
I would do without the lock before I damaged the sensor or screwed up the signal.
bob
Old Aug 29, 2017 | 05:35 AM
Daim's Avatar
They cost less from SNG
Old Aug 31, 2017 | 06:58 PM
tahoemedic's Avatar
I reused mine when I did the front wheel bearings. didn't see the need to replace something that wasn't broken and everything works just fine
Old Sep 1, 2017 | 07:57 PM
Thanks. Got new ones from SNG.
Certainly would have reused old but one of them broke on removal.
