front pad replacement
Old Nov 22, 2009 | 02:51 PM
alshaheen's Avatar
Default front pad replacement
hi can any one tell me if i have to open the bleed point to retract the pistons in the calipers for replacing my pads on a xj8 3.2 2000
thanx
Old Nov 23, 2009 | 01:30 PM
pjkbrit's Avatar
no...unless you are bleeding the brakes at the same time. I would syphon off some fluid from the master cylinder to avoid overflow.
Old Dec 21, 2009 | 06:57 AM
Marc's Avatar
I'm a little late gettin here, but you should bleed off fluid at the calipers and NOT the reservoir. Reason being the fluid at the calipers are heat stressed and need to be replaced on a regular basis. The brake fluid sees extreme heat and pressures starting at the caliper, so you should drain this fluid off first. Also any dirt that gets into the system will settle out at the lowest point which is the calipers.
BrentGardner
29
Dec 16, 2024 12:13 AM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
jdzubas
Oct 4, 2015 09:14 AM
ronald4313jm
Aug 31, 2015 07:58 AM
souldoubt
Aug 25, 2015 08:15 PM
