Front passenger headrest
Old Oct 4, 2018 | 06:10 AM
ade55's Avatar
Default Front passenger headrest
Hi
like a complete Wally I have forced my passenger headrest up on my 1999 xj8 using brute force , not realising it is motor driven , obviously it drops instantly now as I heard something fall off in the seat and can feel a plastic piece lying loose in the bottom of the seat. I have already downloaded how to remove the back of the seat to access inside. Does anyone know what I can expect to do to fix the problem , I presume I have pulled the headrest of some form of retaining bracket.
I will exercise more caution in future .
Ade
Old Oct 4, 2018 | 06:48 AM
Carnival Kid's Avatar
Ade55, this forum link to a similar problem from another member should help you.................
https://www.jaguarforums.com/forum/x...t-move-198830/
Old Oct 4, 2018 | 06:57 AM
Highhorse's Avatar
Hi Ade,
Here's a good possibility of what may have been damaged (a common break on its own) but until you remove the cover, you won't know. The covers simply pull off unless you have the picnic tables, then you need to remove the 4 screws & table then pull the cover off.
https://www.jaguarforums.com/forum/x...0/#post1865880
If you have questions and/or want suggestions for repair after determining your issue, be sure to post pics to assist us seeing what your seeing.
Old Oct 4, 2018 | 01:06 PM
ade55's Avatar
Hi Highhorse
many thanks for your prompt reply and links to help me solve my manmade problem. I will be more careful in the future and think before I start pulling at anything
wish me luck
Ade
itswemy
Nov 27, 2016 07:48 PM
Car-Nut
Jan 20, 2011 02:23 AM
wjhughes420384
Jan 27, 2008 12:02 PM
