Front shocks CATS suspension
Old May 18, 2014 | 07:03 PM
Porsche407's Avatar
Default Front shocks CATS suspension
OK, it seems I keep getting kicked off of posting so I'll try again...3rd time Jim Lombardi is there a problem with the site?
My front shock bushings have "melted" I'm replacing the mounts... Don't want to buy new shocks if I don't need to! How do I tell if I need new shocks? I've replaced the sway bar links because of shot bushings, the ball joints appear to function normally but there are "cracks" in the rubber. How do I check/know I need to replace the shocks? Don't think I have the CATS system, but not exactly sure how to check. The original window sticker is VIN SAJDA15B71M F26638. Feel a "shudder" going over RR tracks or potholes... Any ideas greatly appreciated!!!
Old May 19, 2014 | 02:38 AM
Sean B's Avatar
both the front and rear ends are bushed - with the front subframe v mounts, engine mounts, and rear lower front subframe mounts being suspect in your case.
To i.d. CATS equipped cars, look for a domed black cap that sits on top of the shock and a wiring loom connector running into the top of the shock, if not, non cats equipped.
The shock mount bushes do deteriorate and updated bushes can be purchased to fit, a simple job, have a search for the procedure
Hope this helps
Neil1664
Jan 20, 2022 08:59 PM
Mugatu
22
Jun 23, 2020 01:50 PM
08Z06
Oct 24, 2015 05:46 PM
Tar
Sep 6, 2015 11:24 AM
02jagstype
Sep 4, 2015 08:20 PM
