Front Upper Shock Bushings
Old Nov 16, 2024 | 02:29 PM
cnaj2488's Avatar
Default Front Upper Shock Bushings
Hello all, I have a 2002 jaguar XJ8 that’s needs those upper front shock bushings replaced. The issue I’m having is I can’t find them anywhere. Does anyone have an idea of where I could buy them? Preferably polyurethane or something rubber.
Thank you.
Old Nov 16, 2024 | 02:47 PM
Gator8's Avatar
I presume you mean the bushings that are visible under the hood. They are sold as part of the upper shock mount assembly.
Old Nov 16, 2024 | 03:15 PM
Silverjag0's Avatar
Old Nov 16, 2024 | 05:05 PM
cnaj2488's Avatar
Yes those are the ones I am talking about. Yeah unfortunately all I am finding is the entire shock mount assembly but I only need the bushings.
Old Nov 16, 2024 | 05:14 PM
cnaj2488's Avatar
Originally Posted by Silverjag0
this is the dimensions I see, is it really 4x3x4 cause if I measured correctly the busing area is about 2inx2in
Old Nov 16, 2024 | 08:51 PM
Parker 7's Avatar
As the expensive assembly might consider pouring your own from a 2 part mix
Molding assistance avail from others
2 part mix available on E - bay and such
Your target density ( Shore A ) value is in the range of ...........and this particular suspension component may only be 1 density
Car Fan
Oct 28, 2023 06:42 PM
David N. Warner
Nov 24, 2020 11:01 AM
Jon89
16
Jan 18, 2017 02:10 PM
Alvin Burns
Dec 2, 2015 04:16 PM
