front wheel bearing weakness
Old Sep 21, 2014 | 04:26 AM
plums's Avatar
Default front wheel bearing weakness
Ever wonder why the front wheel bearings seem to be a perennial topic?
Have a look at the list of vehicles using the same bearing:
•Type: Wheel Ball Bearing
•Dimensions: 42mm x 80mm x 45mm/Metric
Fits the following Vehicles
•2009-2006 FORD FUSION
•1997-1993 FORD PROBE
•2009-1996 JAGUAR VANDEN PLAS
•2003-1999 JAGUAR XJ8
•2003-1999 JAGUAR XJR
•2009-2007 JAGUAR XK
•2006-1999 JAGUAR XK8
•2009-2000 JAGUAR XKR
•2004-2000 KIA SPECTRA
•2009-2007 LINCOLN MKZ
•2006 LINCOLN ZEPHYR
•2009-2006 MAZDA 5
•2007-2006 MAZDA 6
•2002-1993 MAZDA 626
•2002-1995 MAZDA MILLENIA
•2006-1989 MAZDA MPV
•2008-2006 MAZDA MX-5 MIATA
•1997-1993 MAZDA MX-6
•1991-1986 MAZDA RX-7
•2009-2006 MERCURY MILAN
Other than the Lincoln MKZ, all of the non-Jaguar vehicles are lighter by somewhere around 1000 lbs with not quite as high cornering abilities.
And the above is the bigger bearing succeeding the 76mm bearing in the earliest models.
Stress a part, or under spec a part ... it fails.
Old Sep 21, 2014 | 04:40 PM
avt007's Avatar
Good point.
Old Sep 21, 2014 | 06:45 PM
D. Fite's Avatar
I haven't seen much discussion about people having problems with these bearings(unless I missed it somehow). I would assume my 02 T Bird has the same bearings also. Definitely something to keep an eye on. Thanks,
Dave
Old Sep 22, 2014 | 09:56 AM
DJ-Roy's Avatar
Is there an upgrade maby a better quality bearing ?
http://www.performancebearing.com/
PMKimpton
Aug 3, 2019 08:22 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
OkieTim
Sep 2, 2015 12:48 PM
