Fuel pump XJ Sport 2000
Old Jun 26, 2022 | 05:34 PM
Addicted2boost's Avatar
Clean the MAF sensor, check for cracks most specifically under the bellows on the air intake tube. You also need to see what the STFT & LTFT’s are if you have a scanner with live data.
Old Jun 29, 2022 | 01:11 PM
RandyS's Avatar
You might check the condition of your injectors. That rusty fuel line may have contributed some
elements into the fuel which eventually wind up there.
Old Jul 3, 2022 | 06:16 AM
JamBar's Avatar
Hopefully a final update on this one.
All is ok. The pressure was low on the pump, swapped out, and now runs fine.
Also new plugs, also a new cam cover gasket as there was oil leaking to some plug wells.
Mad_Russian
XJ40 ( XJ81 )
Jun 15, 2016 11:15 AM
plums
General Tech Help
Jan 17, 2016 02:28 AM
Mkii250
Aug 14, 2014 04:29 PM
wardhill
May 29, 2013 10:45 AM
gunnerman
XJ40 ( XJ81 )
Jun 24, 2010 08:55 AM
