Fuse box layout diagram
Old Oct 1, 2009 | 02:04 PM
goldencharriot's Avatar
Default Fuse box layout diagram
I'm wondering if someone could snap a quick picture of their fuse box diagram on an xj8. Mine is missing and I have no idea which fuse/relay is which. I tried searching but couldn't find one.
Thanks in advance!
Old Oct 1, 2009 | 07:05 PM
NorCalDiesel's Avatar
there are no less than 4-5 fuse boxes/panels, maybe more. Which one are you looking for, or what are you looking to replace.
Old Oct 1, 2009 | 07:29 PM
I'm looking for the diagram for the fuse box next to the battery in a 99 XJ8.
Old Oct 1, 2009 | 10:29 PM
Sarc's Avatar
Isn't there a sticker inside the lid of the fuse box telling you the fuses ? (I can't remember and I'm too lazy to go down into the garage to check)
Old Oct 2, 2009 | 09:20 AM
not on my lid. No location diagram, no list, no nothing, haha! If someone has the diagram i'll print one out and stick it in there.
Old Oct 2, 2009 | 12:58 PM
SuperSport's Avatar
Pages 4-12 through 4-24
This attached Document was downloaded freely from the Jaguar Website. It is for the 2000 XJ's, but I've yet to find a difference in my 1999 XJR.
It shows the Fuse/Relay Locations, and usages.
If you don't already have it installed, you will need the Free Adobe Reader to open the Document:
Old Oct 2, 2009 | 03:45 PM
Thanks! that does list all of the relays and fuses but not which number is which in the box itself. Is that cast into the box per chance? I couldn't see any numbers but maybe I wasn't looking close enough.
Old Oct 2, 2009 | 04:57 PM
Sarc's Avatar
I think you can see the numbers on the fuseholder bodies.... I'll check when I go home tonight
Old Oct 11, 2009 | 05:38 AM
hughey's Avatar
I have this booklet and have looked to see if there is any fuse or relay that controls all of the steering column controls, but haven't found anything. I have no function from any of the controls on the steering column except for the turn signal and wiper stalks. Everything related to those functions properly, but all other controls (column adjuster, cruise control, radio controls, horn) are dead. Any suggestions?
Old Aug 5, 2010 | 09:56 AM
inspector44's Avatar
I tried to download the handbook but it will not let me. Could you please send it to me at brhassell@gmail.com as I would appreciate it.
Old Aug 5, 2010 | 10:00 AM
Default Need handbook.
I tried to down it but it would not let me. Please send to brhassell@gmail.com
Old Aug 5, 2010 | 10:09 AM
SuperSport's Avatar
It's been sent. Let me know if you have any problems opening it.
Good Luck!
Old Oct 10, 2010 | 11:41 AM
alexhauber's Avatar
Anybody have Instructions on how to remove the Exhaust from 2001 XJ8. Seems to be the only way for me to get to the O2 Sensors
Old Jun 26, 2011 | 05:10 AM
dallasisland's Avatar
Id like to have a fuse layout for my 1999 XJ8- Im trying to find the fuses for the engine fans- any help would be appreciated. I cant open the booklet- dallasisland@netzero.com Thanks!
Old Jul 1, 2011 | 05:40 PM
dac44444's Avatar
Default 06 X-Type Owners Manual
It say's I don't have access to this info?
Old Jul 2, 2011 | 03:43 AM
Cadillac's Avatar
Because you're totally a new member you need min 10 posts and a few days , please re read your pm it explains you why
Old Jul 2, 2011 | 09:50 AM
jimlombardi's Avatar
Hi dac44444
I put a 2006 X-Type Owners Manual PDF I created in a new thread in the X-Type section of the forum:
https://www.jaguarforums.com/forum/x...47/#post372395
Jim Lombardi
Old Sep 6, 2011 | 01:08 PM
suzjag's Avatar
Default 2000 xj8 brakes
Ok folks I have a 2000 xj8 and the barke lights stay on all the time. I replaced on burnt bulb and it did not fix the problem. I also unplugged the switch at the brake pedal and they went off. I am guessing that my switch is bad. Anybody had this problem?
