fuse diagram
Old Feb 3, 2012 | 10:52 PM
blackwolf560's Avatar
Default fuse diagram
Anyone have and or know where to get a fuse diagram for a 2000 XJ8 Vanden Plas?
Or better yet, anyone know which fuse is the fuse for the passenger side power seat?
Old Feb 4, 2012 | 01:09 AM
QuadManiac's Avatar
Here's a link to the official electrical guide / wiring diagrams complete with all the fuses - you can follow signals back from the affected device to the fuses.
http://captainjaguarscathouse.com/El...ec%20Guide.pdf
In your case, passenger seat is in Figure 12.4, fused both as the switches and as the Seat Processor Module - at least one of two fuses could be affecting you.
Old Feb 4, 2012 | 01:26 PM
SuperSport's Avatar
Here is an easy to follow diagram for fuses (user friendly ). Starts on page 4-12
Old Feb 4, 2012 | 03:02 PM
thanks
Old Feb 4, 2012 | 03:23 PM
replaced fuse and it works. Some monkey had a 25 in there and it was blown. Now, got a 20 in there and it works. But the headrest button, when pressed to go down, the module just clicks, about three times per quick button. It's small priority though as it's on the passenger side and none of the past five cars I had with automatic adjust headrest, there wasnt a single passeneger ever to touch it or even knew it existed. go figure.
But out of curiosity, is the motor stuck?
Old Feb 4, 2012 | 03:35 PM
SuperSport's Avatar
Mine occasionally does the same thing on the driver side. If I press up and down a few (10) times, it starts to run again. I don't know if it's the motor, relay, or position sensor. I also don't use it much, so have not bothered finding out.
aode06
Jul 28, 2023 02:26 PM
richard bowles
Jun 10, 2023 12:24 AM
baskervillema
Oct 1, 2015 06:43 PM
Lubrication
Oct 1, 2015 03:56 AM
