Fusebox protection module Hot wire coming from inside the car
Fusebox protection module LJE2850AA,wire which is coming from inside the is very hot
sometimes the car wont start i have to move the wire up and down to start the car.
question is
is the wire always hot ???
my battery is more than two year old, car did not start i start the car from another car
is the battery need to replace???
please advise
question is
please advise
A wire should never be hot.
Aside from a short, you might have a loose connection or a break in the wire.
If moving the wire helps, then look at both ends of the wire and make sure that the connecting surfaces are clean and that the connection is tight.
If you disconnect the battery, wait one hour, reconnect the battery, wait 15 minutes and check the wire again without doing anything else, and it is again hot, then you have excessive current draw beyond the wire.
It is not a battery problem, it is a wiring problem.
BrentGardner
29
Dec 16, 2024 12:13 AM
hafren
Aug 30, 2023 03:42 PM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
