Gearbox not changing gear.
Old Jun 21, 2017 | 03:54 PM
Marvelbiz's Avatar
Default Gearbox not changing gear.
Year 2000 xj8 auto. Not changing gear. Message says gearbox fault and high temperature
Old Jun 21, 2017 | 05:02 PM
Kejar7's Avatar
The first thing that I would do is check the fluid level of your transmission.
It is a PITA but this is the first step to a diagnosis.
Has it been changed recently?
RAM
Old Jun 21, 2017 | 05:29 PM
motorcarman's Avatar
Is the gearbox temp ACTUALLY HIGH???
If not then the thermistor integral with the internal harness is faulty.
You will need to replace the gearbox internal harness as the temp sensor is Not Sold/Serviced Separately. (NSS)
bob
iwillfixit
Jun 19, 2017 01:55 PM
FloridaPilot
Jun 4, 2017 06:23 PM
Kejar7
May 29, 2017 10:03 PM
Sceleton
May 29, 2017 10:23 AM
schnikies
May 27, 2017 10:00 AM
