Genuine Jaguar exchange engine rebuild spec?
Old Jul 5, 2013 | 05:25 AM
sparkenzap's Avatar
Allan:
The reason the chain tensioners are different and have the "tensioning" side slipper on the opposite side is that you tension the slack side of the chain. That is important to understand if you are NOT doing the "zip tie" method, since you need to set the sprocket positions after assuring the chain slack has all moved to the slack side.
Old Jul 5, 2013 | 12:50 PM
Maninahat98's Avatar
Originally Posted by sparkenzap
Allan:
Ahhhh, I see, thank you, so obvious now you pointed it out...feel silly now! LOL Allan I will be doing the zip tie method.
Old Jul 6, 2013 | 10:48 PM
WaterDragon's Avatar
Originally Posted by avos
What is your engine serial number?
Which car? The XJ8 or R?
And I should ask where to find the number on the engine?
Old Jul 7, 2013 | 12:31 AM
avos's Avatar
Although I referred to your post with your xjr, you can give both of course
Attached Thumbnails Genuine Jaguar exchange engine rebuild spec?-engine-serial.jpg
Old Jul 7, 2013 | 04:29 AM
Allan:
Thanks for all your help guys, I changed mine yesterday, all good.
thanks, Allan
Old Jul 19, 2013 | 10:28 AM
avos's Avatar
@Waterdragon,
Its common knowledge that you have to look at the engine serial to know if you have the later good tensioners or not, so am surprised you say it should be via the VIN number, so you have been misinformed there.
After this time I'll take it you can't find the engine serials, which is a shame as it would be good info just to verify, so if you can still look them up that would be great.
Old Jul 19, 2013 | 10:44 AM
@Waterdragon,
Hi,
Sorry for the delay, I have been super busy on more productive issues, and my "working on the car time" has been entirely spent getting my new 2000 XJR ready to go back together as soon as all my sent out for porting parts return.
Yes it should be the engine serial #, which is the number I gave the mechanic and the dealer way back when, they also used the VIN for some reason to verify it was "my" car before giving out any information at the dealer.
This was last January so I had forgotten where the engine vin was. So where is the engine vin on the XJR and XJ8?
My verification method however was overriding proof since I pulled valve covers and then removed the orange plastic cracked tensioners and upgraded them to aluminum. This is why I say the dealer or random indy mechanics cannot be trusted on this issue. One must pull a valve cover and have a direct look.
Old Jul 19, 2013 | 11:05 AM
  #28
BW_Hunter's Avatar
Please excuse my ignorance, but just where on the engine is illustration 'A'. My 98 should have a number as defined by illustration 'A' but there is nothing there. I suspect the engine may have been changed out...
Old Jul 19, 2013 | 11:29 AM
avos's Avatar
The A spot is for engines from 2001, so if you think you have an engine from 98, you need to check the B spot, and that one is sometimes hard to find, especially for supercharged cars iirc.
Old Jul 19, 2013 | 11:45 AM
  #30
BW_Hunter's Avatar
I did check the B spot and there is nothing there...no maching or rmarking of any kind.
I was actually wondering where the A spot is on the engine so I can look there as well. I'm thinking the A spot is under the exhaust manifold on the left side but not truely certain...
Thanks,
fast40driver
Apr 19, 2024 07:24 AM
Isoruku
Jun 19, 2020 12:54 PM
rusty37
Jun 7, 2016 04:43 PM
Dion Petty
Aug 30, 2015 01:00 PM
TC Johnson
Aug 29, 2015 08:55 PM
