Grille Interchangeability XJ8
Old Jan 14, 2013 | 10:45 AM
robertjag's Avatar
Default Grille Interchangeability XJ8
Will an OEM Vanden Plas grille assembly (fluted) interchange, without modification, with a regular XJ8 grille?
Also, will the back fluted trunk "bar" off a Vanden Plas do the same?
Thanks!
Old Jan 14, 2013 | 10:59 AM
danielsand's Avatar
They are both a direct swap. In the back, you might have some paint fading to deal with, after you remove the longer bar.
Old Jan 14, 2013 | 11:29 AM
robertjag's Avatar
Car has been repainted recently (few years). I will check to see if the bar was taped or removed for repaint. Thanks!
Joachim1167
Nov 7, 2020 09:18 PM
X308XJR
May 20, 2019 06:50 PM
magmedia
Oct 8, 2015 03:28 PM
donald ebanks
Sep 30, 2015 07:08 PM
