Hanger Bearing is like Hens Teeth, Cant find
Old May 10, 2016 | 03:53 PM
cjesse444's Avatar
Default Hanger Bearing is like Hens Teeth, Cant find
I have a new to me 1999 Jaguar Vanden Plas 49,000 miles and I am really pleased, my first Jag. Done regular upkeep work, brakes, fluids etc but had a nagging dragging sound. Finally brought it to my indy and put it on the hoist in drive and with a stethoscope it was diagnosed as a bad Driveshaft Center Support Bearing. For the life of me I cannot find the assembly complete nor can I find the bearing specs to have a new one pressed in.
Did find this:
"the hanger bearing is not sold for a 98 and up but it is sold for a 95 to 97 xj6 and i have removed and replaced the hanger bearings before and used a 95 xj6 hanger bearing and sleeve cover for slip splines and it has worked fine 5 time so far. "
Any advice would be appreciated
Old May 10, 2016 | 04:07 PM
XJ8JR's Avatar
I have a brand new one that fits the 1999 S-Type. It also fits on my 05 XJ8. Not sure if it would fit yours though. I was planning on installing it, but the issue turned out to be something else. Brand new sitting in a box. PM me if you can verify it will fit your car.
Old May 10, 2016 | 04:15 PM
cjesse444's Avatar
I would be interested but my quest is to find out what fits. So stay tuned
Old May 10, 2016 | 04:20 PM
plums's Avatar
See if you can find the posts that state the part from
the X300 is listed separately and fits.
There should be at least three from memory.
Old May 10, 2016 | 04:24 PM
cjesse444's Avatar
Thanks Plums, I am good at searching and found the one reference but nothing else. Even tried Google.
Maybe Prop shaft bearing as search
Old May 10, 2016 | 05:23 PM
cjesse444's Avatar
Jag Bits
Jaguar Carrier Bearing
1998-2008 XJ8 and XJR
Old May 10, 2016 | 05:33 PM
cjesse444's Avatar
Sorry wrong cut and paste above
Jaguar DRIVESHAFT CENTER SUPPORT CARRIER BEARING - EBC9040-OE
DRIVESHAFT CENTER SUPPORT CARRIER BEARING Fits: Jaguar 1979-1989 XJ6 AND 1992-1997 XJ6
Part Number: EBC9040-OE
Price: $129.95
Old May 10, 2016 | 05:35 PM
cjesse444's Avatar
As a side note the Jag Bits fella says you need to buy the whole drive shaft and he gets calls all the time for the hanger bearing. He has never had someone use the above xj6 carrier bearing for a xj8
plums's Avatar
No, that is for the rear hub.
Go here:
Genuine Jaguar Parts and Jaguar Accessories for classic Jaguars from Jaguar Classic Parts UK
and use their catalog for the X300 series.
On the X308, it comes only with a new prop shaft.
The X300 has it available as a separate service part.
Old May 10, 2016 | 05:42 PM
cjesse444's Avatar
JAGUAR XJ SERIES X300 PARTS - PROPSHAFT-3.2/4.0 LITRE-AUTOMATIC GEARBOX
No. Description Price Quantity
0 + (Unillustrated Parts)
1 + Propshaft
2 + Universal joint kit
3 + Centre bearing
+ automatic
+ 3.2 Litre
+ 4.0 Litre
EBC9040 £80.95
Plums are you confident it will fit? I will be thrilled
Old May 10, 2016 | 06:53 PM
plums's Avatar
The reports say yes. I have no direct experience.
My guts say yes given the predeliction of manufacturers
to raid the old parts bins.
You could go find a friendly indy with a X300 on the lift
and compare. That would be the most reliable way.
Or, post a new thread along the lines of
Will a X300 hanger bearing fit a X308.
That might twig someone's memory.
Copy paste the above info into that post
to make it easier.
edit:
I will remind you that you yourself started with this:
Did find this:
That would be your EBC9040 £80.95
Old May 10, 2016 | 09:29 PM
cjesse444's Avatar
Sounds like a plan plums, I will order a 95 xj6 hanger bearing EBC9040 and give it a go. Tell me something, do I need to get a "95 xj6 sleeve cover for slip splines"?
What does "i have removed and replaced the hanger bearings before and used a 95 xj6 hanger bearing and sleeve cover for slip splines and it has worked fine 5 time so far. " mean to you?
Old May 10, 2016 | 10:01 PM
plums's Avatar
can you post the link to the original thread?
My interpretation is that the writer has done it five times
with success.
The sleeve cover does seem like it might be critical. Perhaps
a different size than on the X308. It might be in the "unillustrated parts"
or "prop shaft" section of the page you quoted:
1 + Propshaft
3 + Centre bearing
+ automatic
+ 3.2 Litre
+ 4.0 Litre
EBC9040 £80.95
Old May 10, 2016 | 10:03 PM
plums's Avatar
One other thing:
please post all dimensions and markings on those parts
once you have them in hand.
that way we might be able to collectively figure out a
suitable alternative in the future.
Old May 11, 2016 | 06:13 AM
cjesse444's Avatar
I dont see a sleeve cover?
1 + Propshaft
3 + Centre bearing
4 + Propshaft gaiter
5 + Flexible jurid coupling
6 + Coupling bolt
7 + Coupling washer
8 + Locknut
9 + Coupling bolt
10 + Coupling washer
11 + Locknut
12 + Centre bearing mounting bracket
13 + Flanged head screw
14 + Centre bearing washer
15 + Spacer
16 + Aluminium spacer
17 + Anti twist bracket
XJ Series (From (V)720125 up to (V) 812255)/TRANSMISSION AND DRIVELINE/PROPSHAFT
Old May 11, 2016 | 07:11 AM
cjesse444's Avatar
Default GREASING Propshaft Center Support Bearing
This appears to be an temp solution to quiet it down, thoughts
Propshaft Bearing Grease Story by James Fenley (jfenley123) | Photobucket
Default RE: DENNIS'S POST - GREASING Propshaft Center Support Bearing
As you all know, this seems to be a commonproblem with the X-type (all years) and many here have replaced their entire Prop shaft as a result of the Center Support bearing failing or begins to howl, vibrate and whine.
First of all, KUDOS goes to Chas944, for giving me tips and inspiration to do this in this post HERE.
Mine was not showing any signs of failure or noise, so this was preventive maintenance to prolong it's life...
I found the bearing outside caked in hardened old grease and there was surely not much left inside..I cleaned both side off, so I could make out where the rubber seal and bearing housing met..the front side (side towards the front of the car) had no visible entry points or means of penetrating to inject grease...The back side (side facing the rear of the car) has little notches in the rubber seal on the edge where it meets the metal bearing casing..These notches are at 6 o'clock, 10 o'clock and 2 o'clock...I'm sure there is one at 12 o'clock, but not able to get at it..
TOOLS and SUPPLIES
*Standard Grease Gun
*Grease Gun HOSE about 18" long
*18 Gauge Grease Injection Needle
Click the image to open in full size.
Grease:
Note: Warm grease in hot water to about 100 degrees F, to make it flow easier out the needle.
Insert Grease Needle (it goes in about half way)into the 6 o'clock notch on the rear side of bearingand pump until you see new grease oozing out from the bearing on the front side..
Continue with the other two postions (10 o'clock and 2 o'clock)in the same way..
10 o'clock
2 o'clock
Wipe off all the excess and be on your way with a freshly Greased Bearing.
__________________
03 Jag X 3.0L loaded BRG
Senility is to forget the people I don't like and having the pleasure of meeting the ones I do.
__________________
02 X-type 3.0l
04 S-type 3.0l
07 X-type 3.0l
See the complete saga in picture format
James Fenley's Library | Photobucket
also for more info
http://www.drivehq.com/web/jfenley/
HAVE FUN!! and ENJOY the RIDE
Old Mar 30, 2017 | 06:47 AM
McTheKnife's Avatar
So what was the conclusion to all this? Did the EBC9040 part from the X300 fit on to your 1999 X308?
The rubber mounting in mine seems have gone a bit soft. I can get movement of 5 mm (~1/4") of the central bearing relative to the outer mount with not much force which seems a bit excessive to me.
Old Mar 30, 2017 | 09:05 AM
cjesse444's Avatar
The conclusion was that it was a huge to do to have the part replaced and I was told they rarely fail. So I found a low mileage x308 at the breakers and bought the entire driveshaft. The job to replace is not difficult but they had to cut the exhaust to get access. All is good
multiplecats
General Tech Help
27
Apr 5, 2016 09:42 AM
Paul_59
Apr 2, 2016 07:18 PM
andyh1108
Apr 2, 2016 11:17 AM
xkeots
Mar 31, 2016 02:03 AM
kapows
Mar 30, 2016 02:09 PM
