harmonic balancer
Old Dec 4, 2013 | 08:21 AM
bleedblue427's Avatar
Default harmonic balancer
Need some help i am in the process of tearing down the front on my 98 XJ8 VP. I cant get the bolt for the harmonic balacer off. Using an impact I got it started off but is now stuck half off. It was alot of work getting it this far. Are these lock tight on? Can or will some heat help? Is this common?
Old Dec 4, 2013 | 12:12 PM
platinummaker's Avatar
Just completed this job while doing secondary tensioners and guides etc for my son's XJR. We tried to remove bolt without official Jaguar tools. Breaker bar turned the engine without loosening bolt, air ratchet ineffective as well. Resorted to back on the farm techniques. Put breaker bar on bolt and held it against small block of wood on driver's side fenderwell, my son cranked the car(fuse pulled for fuel pump to guarantee no start) The torque of the engine caused bolt to break loose enough for easy removal with ratchet. Pulley was most difficult to remove and required a beefy puller. Good luck
Old Dec 4, 2013 | 12:17 PM
Tried that got the bolt broke loose and half loosened now stuck wont tighten or loosen. Have matco and snapon impact and running un regulated air at around 170lbs and still nothing thinkin if a 1in impact will fit trying that but got to barrow one
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
jonahjob
Oct 1, 2015 07:54 AM
AnD3rew
Sep 26, 2015 06:06 PM
Dicque
Sep 12, 2015 10:34 AM
