Head gasket
Old Nov 7, 2016 | 03:07 PM
afc1903's Avatar
Default Head gasket
Hello. Is there a step by step to replacing the head gaskets on a 98 v8 sovereign? Thanks
Old Nov 7, 2016 | 05:20 PM
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
Old Nov 7, 2016 | 07:15 PM
avern1's Avatar
The first place to start is to go to the "HOW-TO" section and download the JTIS to your computer. It is the tech manual system for repairs. You will need it for the timing procedures and for torque values and procedures.
Your going to need the special tools for TIMING and the special tools for removing the HARMONIC BALANCER.
If you use the search tool at the top ribbon on the x308 page and use the advance search function for the x308 you can get details on removing the components from different threads. You can also search the XK8 forum as they use the same engine.
I remember from another post that the head bolts are a one time use and have to be replaced. They are torque to yield. If you search also for head gasket recommendations you will get the part numbers for the metal MLS head gaskets. They seem to be the one everyone recommends.
Hopefully a few others will chime in with recommended part numbers and tips.
Old Nov 7, 2016 | 07:38 PM
RJ237's Avatar
You will find this of value, also:
http://jagrepair.com/images/AutoRepa...Code%20168.pdf
Old Nov 7, 2016 | 11:38 PM
afc1903's Avatar
Thanks for the info lads.
Old Nov 12, 2016 | 10:09 AM
dsetter's Avatar
I found the MLS gaskets and bolts were cheaper for the land rover equivalent 4.2 engine. The bolt heads however are a size 10 RIBE drive. Much more positive torque than the 13mm originals.
LAND ROVER CYLINDER HEAD GASKET SET 4.2L 4628400 4628399
BOLTS 4677857
http://www.ebay.com/itm/LAND-ROVER-CYLINDER-HEAD-BOLT-RANGE-ROVER-4-4-LR3-V8-4-4-LR4-SPORT-SET-4677857-/361623703678?hash=item543273d07e:g:8pwAAOxy~dNTIh5 T&vxp=mtr
Old Nov 12, 2016 | 01:55 PM
afc1903's Avatar
Started stripping today. Big job . Struggling to get the bottom pully off. Any tips? Some heat maybe?
Old Nov 12, 2016 | 02:29 PM
BobRoy's Avatar
I use a breaker bar with a 5' piece if pipe over it to break bolt loose. I have the proper kit to remove crank pulley. I would do a search for other members methods of removing the crank pulley without the kit.
Old Nov 12, 2016 | 02:41 PM
afc1903's Avatar
Got the bolt off no problem but the pully is stuck fast. I will try and fabricate a pully puller. Thanks bob
Old Nov 12, 2016 | 02:46 PM
nilanium's Avatar
I had pretty good luck using an ordinary harbor freight pulley puller, just be sure to stick several washers under the stationary bolts or they can pull through the puller plate. After you move the crank pulley out a few mm you can give it some good knocks around with a hammer to vibrate it loose and it should just come right off. This is the procedure in JTIS and lots of forum guides here too.
Old Nov 12, 2016 | 03:12 PM
afc1903's Avatar
Cheers . I will have another go this week sometime. Looks like it is going great to be interesting this jag world.
Old Nov 13, 2016 | 07:37 AM
motorcarman's Avatar
Why not just read TSB 303-10 and follow the instructions???
Jaguar already gives you 'how-to'.
All this info is here in the large file area.
bob
Old Nov 13, 2016 | 03:13 PM
afc1903's Avatar
bob
where do I find this bob? Am no good wee computers. Thanks steve
Old Nov 13, 2016 | 03:36 PM
BobRoy's Avatar
When you can't find something do a search. I copied it for you by doing a search.
https://www.jaguarforums.com/forum/a...jag-303-10.pdf
Old Nov 18, 2016 | 05:36 PM
afc1903's Avatar
Out of interest lads. How much should i expect to pay for a latest generation chain kit and 2 head gaskets? Just curious. Thanks steve
Old Nov 19, 2016 | 10:58 AM
dsetter's Avatar
$100 for 2 head gaskets
$60 for 20 head bolts
$250 for primary/secondary chain tensioner kit
$50 for front cover and crank seal
May need manifold seals, although exhaust can remain on, still need manifold to pipe seal, $6
Old Nov 19, 2016 | 11:44 AM
afc1903's Avatar
Thanks for reply. Is ther a place in the states that would sort me out with a chain kit? Been pricing here in uk ? Expensive motors these jags. Finally got my crankshaft pully off. Both heads and chains off . So just need gaskets and chain kit and the auld lass will be raring to go again. Also water pump.
Old Nov 19, 2016 | 11:18 PM
dsetter's Avatar
Try looking for a htk100 chain kit.
http://christophersforeigncarparts.com/products/jaguar-v8-4-0l-1997-2001-timing-chain-kit-htk-101
Old Nov 20, 2016 | 02:48 AM
afc1903's Avatar
decent price, anyone know what taxes might be coming into the uk?
