Headliner Replacement Question
Old Dec 26, 2012 | 10:19 PM
Iconoclast's Avatar
I used Saggy Stoppers:
Amazon.com: Heads Up HU850 Saggy Stoppers Fasteners: Automotive
Worked & The sagging headliner in the back seat could no longer droop down! But, I KNEW it was there & it was only a temp fix for me. So, I paid a professional upholstery shop to replace the headliner. ($310 total) Not the sun roof liner. That would have been $50 extra at the time & even more if I later did it. But, as explained by the shop, the sun roof headliner was already completely sagging . I.E. not glued at all. However, due to the small area the full droop was barely noticeable & not a problem unless your head is almost touching the roof. Mine is NOT. It cannot sag any farther. This is not the case for the rest of the headliner although in the XJ8s it is common to sag above the rear seats where the roof has that upwards angle to allow for headroom for the rear seat passengers. The color match is not perfect but, it is very close to the sun visors & sun roof OEM material. Only I can tell if I look very closely. I am very satisfied with the color match.
There are online videos, tutorials to DIY. Getting the roof board out of the car & back in is the tricky part & I didn't want to bother. Put all thoughts of somehow re-gluing the portions that sagged out of your head. Once you see how to do the replacement you will see why the material must be trashed & the board scrubbed b4 new material is glued down. You probably will have to bend the board to get it out of the car & ask the upholstery shop if they intend to bend it. Mine still has a visible slight crease where they bent it & I'm not thrilled about that since they failed to mention it.
Old Dec 27, 2012 | 10:15 PM
JaguarXKR's Avatar
What is the difference between ordering stock Jaguar headliners vs aftermarket ones?
Old Dec 27, 2012 | 11:48 PM
Iconoclast's Avatar
Not sure you CAN order Jag Headliners. When I went to dealer to replace my headliner they said they send the cars to an Upholstery shop & gave me the name of who they use. You can ask. I imagine dye lots vary & colors fade & suppliers change especially after many years so, an exact, perfect match is not possible.
Old Mar 10, 2016 | 06:18 PM
xj8 detroit's Avatar
Default Oatmeal headliner material
Originally Posted by Kansas99XJ8
I did the job my self. Found a perfect aftermarket fabric match for the "oatmeal" interior from yourautotrim.com Color is PH1784 Sand Gray. This fabric is available from a number of suppliers that can be found with a google search. It is difficult to remove and reinstall the headliner board without bending (i.e., folding) it to get it out of the rear passenger door. There are instructions on how to do this on the net -- just do a search. I was quoted $600 us by an upholstery shop, but the color of the fabric they wanted to install didn't match. Good luck.
Thanks for your post, I purchased the Sand Gray fabric from yourautotrim.com for my 1998 XJ8 headliner and it was perfect for my Oatmeal interior. Not only was the color a perfect match but the fabric had the exact same look and feel as the original. It's at least made the first step of my headliner project a bit easier.
Old Jun 3, 2016 | 11:22 PM
vegasjagclub's Avatar
Default easy sagging headliner solution
HI. Just get spiral upholstery twist pins. 30 cost less than six dollars.
Old Jun 4, 2016 | 07:34 AM
Jhartz's Avatar
Those do a crappy job. Staples are far better and are far less obvious.
Old Jun 5, 2016 | 11:46 AM
WaterDragon's Avatar
Originally Posted by Boomer from Boston
Stiletto heel holes in the headliner ??? I'm impressed!
I believe this earns him the right to swap his "Jaguar" badge on the back of the car to a "SHAGuar" badge! Kind of like the mile high club.
Heh...
Old Jun 5, 2016 | 06:40 PM
  #28
D. Fite's Avatar
Had mine done about three years ago by a shop near me. Matched the fabric perfectly and did a perfect job, still looks great.
Old Jun 6, 2016 | 11:01 AM
bdboyle's Avatar
Had mine done while the rust in the rear window was being taken care of. Shop had 3 on the bench at the same time from Jags.
Before.
fast40driver
Apr 19, 2024 07:24 AM
philwarner
Dec 6, 2021 07:13 AM
Mac Allan
Oct 12, 2015 11:59 AM
Will P
Aug 27, 2015 06:52 PM
dpappyp
Aug 27, 2015 06:31 AM
