Heater control valve bypassed
Old Mar 24, 2018 | 03:24 PM
Ibexlatham's Avatar
Default Heater control valve bypassed
I bought a 1999 XJ8 with a dead trans and poorly running engine as a project (Jaguar Specialites LS Swap and such)
In the process of pulling the engine I found out it seems the previous owner disconnected and removed the heater control valve.
Does anyone have a diagram of how the hoses should be hooked up to the heater control valve and where they go to? Is it worth replacing the valve or is the POs “fix” acceptable for a car that would be intermittently driven (I do like having heat...)
Attached Thumbnails Heater control valve bypassed-6548b5bf-7f14-46db-ad5a-53e04dc8e7fe.jpeg   Heater control valve bypassed-e4180b6b-8cf2-4ab5-b96b-3b1daebb6063.jpeg   Heater control valve bypassed-9346adc1-93d7-4203-a767-45a22aaf79d1.jpeg
Old Mar 24, 2018 | 03:31 PM
Lady Penelope's Avatar
Old Mar 24, 2018 | 05:05 PM
Highhorse's Avatar
They bypassed the heater core in Illinois? That is usually only done for one reason, the core was leaking.
Old Mar 24, 2018 | 05:26 PM
All you can do is hook it up and see if it leaks . My bet with the previous owner it was to complex a concept to effectively deal with and they punted .
Terry H
Oct 28, 2016 04:47 PM
shanshan
Dec 8, 2013 10:10 AM
P4nth4
Dec 10, 2010 12:52 PM
trauch
Nov 1, 2010 08:53 PM
