heater not working
Old Feb 8, 2023 | 07:39 PM
David N. Warner's Avatar
You can find some on Ebay. Not terribly expensive and might get you going relatively quickly.
Here's a link. I made it tiny...
https://tinyurl.com/48t2tk5v
Old Feb 9, 2023 | 12:12 PM
Vauxi's Avatar
I Ordered brushes locally that are really close to correct size. I Need to file them down to a size. Seems to that no one stores any brushes here at all. No one repairs anything anymore so parts are rare.
Old Feb 14, 2023 | 06:35 PM
PeteK812's Avatar
Default But what about the intermittent issue?
The original poster says the problem is intermittent. Does the auxiliary pump fail that way? I last drove mine in freezing weather and the outlet temperature was freezing to match. Today I went for a drive in light jacket weather and the heater blasted me out of the car. I'm going to take my temp gun with me to chronicle the output, but there is no doubt about the difference. Last time, no heat at all. Engine up to temp, but chattering teeth at the driver's position. Today, heat works just fine.
Old Feb 15, 2023 | 08:43 AM
Hooli's Avatar
From memory of other threads mentioning it. The heater pump is like a pond pump, the impeller is magnetically driven so I'd guess if there's some crap in there blocking it at times you could get intermittent issues.
Old Feb 15, 2023 | 09:51 AM
Parker 7's Avatar
There is the thing of tapping on the heater pump with a broom handle as this will jar the bruches loose to settle in to make better contact and run
but this would indicate time to replace them
the relay can be floating causing intermittent contact and you can junper between socket 3 and 5
The 2 power courses to the relay.................
Point 5 square is hot at all times
point 49 double hash circle is fuse # 3 / 10 amp engine compartment fuse box which is dependent on the ignition positive relay in the engine compartment fuse box to be closed , and your engine is running
The A / C control module is providing a ground on the red marked wire in the pic
the heater valve is provided power as the blue wire and goes on through to the shared ground point
Stu 1986
Oct 6, 2018 04:43 PM
Jeronimus
Mar 27, 2017 12:53 AM
steve853
Nov 6, 2014 11:40 AM
hedzup
Mar 23, 2013 05:46 PM
Blue_XJ8
Jan 24, 2013 07:26 AM
