Help
Old May 31, 2015 | 06:53 AM
jagmanv8's Avatar
Default Help
Hi folks....does anyone have a suggestion as to what I've done!!!
I have a 199 V reg v8 3.2 xj sport. I jacked it up last week and took the wheel off but before I could get my axle stands underneath, it fell off the jack and landed heavily on the FOS wheel disc. It now wont start or move out of park. The following messages are now constantly showing....Engine failsafe mode. Gearbox fault. Suspension fault. Electrical fault and wrong part fitted.
Have I killed it?
Old May 31, 2015 | 07:07 AM
andrew lowe's Avatar
Have I killed it?
Has it tripped the inertia switch?
It is located behind the right hand kick panel.
Details are on page 71 of the drivers handbook.
Old May 31, 2015 | 12:04 PM
jagmanv8's Avatar
Default Inertia switch
Hi Andrew....thanks for your reply...I've located the switch and the battery is on charge at the moment as the constant fault readings has drained it over the last week, as soon as its back on i'll go through the reset process and let you know.
Dave
Old Jun 1, 2015 | 05:39 AM
jagmanv8's Avatar
Default Thanks
Hi Andrew...Thanks a bunch.......put the charged battery on this morning and went through the inertia switch reset and every things OK....no fault messages and I can move the gear selector now.....I can now get back to sorting the starter motor, which I was doing in the first place, but i'll place the axle stands before taking the wheel off .What a relief.
Old Jun 1, 2015 | 06:31 AM
Glad to be of help.
But please put safety first as you DO NOT want a Jag landing on any part of your body!
