Help! 1998 xj8 VDP won't start
Old Jul 27, 2009 | 02:12 PM
JagtechOhio's Avatar
There's tons of information on this forum, but it isn't alwys easy to zero in on when you try a search. Punch in my screen name and start reading posts, you won't have to go back too far.
Old Jul 27, 2009 | 05:54 PM
Thermo's Avatar
Veteran: Navy
Mike, I would tell you to connect up a fuel pressure gauge to the car and see if you are getting any fuel pressure. With the engine not running but the fuel pump going, you should be up around 40-50 psi. If the engine does run, then the pressure will drop to the 30-40 psi range. If the pressure remains down at 0 psi (or less than 20 psi), then you have either a bad fuel pump or a wiring issue associated with the fuel pump. If you are up in the 40 psi range, then you have bad gas.
I am placing money on bad gas. You may want to try a bottle of dry gas, but how well that works will be a function of how much water is in the tank. If you are in a place that has recently gotten a lot of rain, it is possible that the underground tanks have gotten water in them and now you are going to be getting a full tank of water, not gas. While uncommon, it can happen.
JarodL
Mar 7, 2024 01:39 AM
Bcrary3
Sep 12, 2021 05:41 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
Charlene n John
Sep 28, 2015 06:01 AM
Charlene n John
Sep 6, 2015 11:03 AM
