Help please - for the newbie with an XJ8 that won't start.
Old May 2, 2009 | 07:03 PM
NorCalDiesel's Avatar
Put your your pedal all the way to the floor. It will shut off fuel delivery while you crank it over. It may take a little bit of cranking, but make sure you have your gas/fuel pedal pegged to the floor and crank it over... When it starts to catch a bit keep it cranking. Once it feels like it is running let off the gas pedal.
I've had to do this more than once when it is flooded.
Old May 2, 2009 | 11:57 PM
JagtechOhio's Avatar
Take the plugs back out. Fill a pump oil can with 5W30 oil, and stick a two foot piece of vacuum hose on the end. Feed the hose down into each cylinder through the spark plug hole, give each cylinder four squirts. Put the plugs back in and start your car...don't wory about the smoke, the oil will burn off after a minute or two.
Old May 5, 2009 | 12:09 AM
diesellee's Avatar
Default Try again
I've had this happen twice within the last two years. My wife would move the car to use another car. Then tried starting it the next day... nothing.
Do as Jagtechohio states with squirting oil down each cylinder. Then do as NorCalDiesel instructs. Peg the pedal to the florr and hold it there and then crank the engine until it starts to catch. Then just depress a little when its catching and it will start.
Dagny
Jun 11, 2024 01:06 PM
99xk8guy
May 28, 2024 09:36 PM
Charlene n John
Sep 28, 2015 06:01 AM
Jdthomas
Sep 23, 2015 06:23 AM
Charlene n John
Sep 6, 2015 11:03 AM
