High pitched noise from the top of the engine bay
Old Oct 27, 2018 | 05:14 PM
vincent661983's Avatar
Default High pitched noise from the top of the engine bay
High pitched noise like a power drill coming from the top of the engine bay, seems like from either the supercharget or throttle body.
Please helo or advise
Old Oct 27, 2018 | 06:21 PM
King Charles's Avatar
Check for air leaks @ throttle body.
Old Oct 28, 2018 | 07:24 PM
This noise
Old Oct 28, 2018 | 10:24 PM
M. Stojanovic's Avatar
It is most probably from the TB. The throttle motor is operated by a PWM signal which has frequency of about 300 hZ.
If you listen to this a 300 hZ audio sample (https://textmechanic.co/300Hz.ogg) you will find it similar to the sound you have.
Old Oct 29, 2018 | 07:58 PM
Noise is from the tb indeed as i checked today, anyone else can advise?
sk1
Jul 2, 2018 05:07 PM
Sixx Dogg
Oct 14, 2012 06:55 PM
jaysto
May 31, 2009 02:51 PM
