Hood/bonnet extremely trembling
Old Sep 22, 2018 | 09:03 AM
Johnjagxj's Avatar
Default Hood/bonnet extremely trembling
Whenever driving at higher speeds, the bonnet/hood trembles very hard, even on a flat surface. I really can't find out what is causing it, checked the metal connections and have made sure it is correctly closed, lubricated. From the moment the speed drops below 140km/hour it does not move and is perfectly still. I know it is not normal because I had 3 XJ's before and none of the hoods trembled. I only have this Jag for less than 2 months know and have no ideas left. It seems to be caused by air but I can not figure out where from. When my wife drives, she is afraid the entire car might take off.
Anyone any ideas? Thanks in advance!
Old Sep 22, 2018 | 09:25 AM
M. Stojanovic's Avatar
Did you check that the bonnet hinges (at the front) are tight? Another possibility is that your engine mounts are shot allowing one side of the engine to lift up under higher stress (higher speeds) and contact the underside of the bonnet.
Old Sep 23, 2018 | 02:46 PM
Johnjagxj's Avatar
Thank you. Checked the hinges but now a part of the undertray seems to be missing. Will get a new one and see if that fixes it.
JimC64
28
Sep 9, 2025 03:28 AM
Doutt
Aug 3, 2020 02:15 PM
l3uddha
Mar 14, 2016 02:43 PM
yabaman
Feb 21, 2015 01:17 PM
bryanc
Jul 31, 2008 06:55 PM
