how to change trans rotary sensor
Old Feb 13, 2013 | 06:46 PM
RidenXj8's Avatar
Default how to change trans rotary sensor
Ow can I change trans rotary sensor (aka trans range sensor) without dropping the transmisssion? I no location and stuff jus wondering if neone has any advice
Old Feb 13, 2013 | 06:56 PM
Gus's Avatar
Gus
Why do you need to do this?
Old Feb 14, 2013 | 08:35 AM
RidenXj8's Avatar
Im gettin gear box fault n trans range sensor code...im having to play with gear selector to go into drive properly...somtimes it feels like it starts in 4th gear...it feels lke it doesnt engagw park fully...but once I shut off n restart car the message goes away and it runs normal. Trans was rebuilt minus the sensor...my only thoughts were the sensor, tcm, or a drum in the gear box
Old Feb 14, 2013 | 08:45 AM
Gus's Avatar
Gus
Is that a ZF5HP24 transmission? If it is you can make an adjustment on the cable and if that is not the problem then you have a selector switch mounted on the right side of the transmission but that is a bit pricey.
Old Feb 14, 2013 | 08:50 AM
RidenXj8's Avatar
yessir it is...how do i adjust the cable?? fyi ur site is killer i use jagrepair like crazy...if i pull the sensor out of a used one will it be ok or is it not a reuseable part...because im literally leaving in 30mins to go try an pull one off a car in indiana if its not ide love to not waste a trip that far...is the switch in the engine compartment closest to the computer ???
Old Feb 14, 2013 | 09:30 AM
RidenXj8's Avatar
Also im wondering how to access it without dropping trans
Old Feb 14, 2013 | 11:22 AM
Sean B's Avatar
the adjustment is with the cable mounting under the centre console. Remove this, slacken the two big ring nuts a little, it doesn't need much, and move the selector through it's full range. Easy to do with the car running on stands at the rear. Button back up once it feels right, no errors etc. Can be done in under 1 hour....
Hope that helps.
Old Feb 14, 2013 | 11:40 AM
Gus's Avatar
Gus
I am looking for the procedure for the cable adjustment. I recently did my xk8 and this is that procedure but I am not sure it is the same for your car.
This link is for XK8/R Not XJ http://jagrepair.com/images/TSB/307-01-1.pdf
When I find it for your car I will post it.
Old Feb 16, 2013 | 01:54 AM
RidenXj8's Avatar
no good wasnt the fix... i went to the junkyard today and found a 98 xj8 with the trans in it still i took 2 bolts off the switch i didnt have a mirror i couldnt see up in there but it didnt come right off and it seemed fragile so i left it im going back tomarow morning any advice or idea if there more bolts im not seeing or if i should gently pry it off with a flat head?
Forcedair1
Sep 8, 2025 01:57 PM
H20boy
Dec 24, 2024 03:23 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
gregster41
General Tech Help
Sep 4, 2015 03:51 PM
arnoldmilk
Sep 3, 2015 07:42 PM
