How to check fuses with rear door open?
Old Jul 5, 2015 | 01:46 PM
chris-jag's Avatar
Default How to check fuses with rear door open?
Hi,
I'm trying to check the X308 for a parasitic draw - the battery draining over about three days - the draw is about 0.5amps.
I've checked all the fuse boxes apart from the ones under the rear seats:
The problem is that when I open the rear door, the ampage goes through the roof because the jag notices that the door is open!
Does anyone know how to trick the jag into thinking the door is actually closed?
I'm beginning to think that I'll need to remove the door card and disconnect something in there.
Would appreciate it if anyone knows the proper procedure!
Chris
Old Jul 5, 2015 | 02:38 PM
Daim's Avatar
Simply lock the door. Use a screw driver to strike the catch and done.
Old Jul 5, 2015 | 03:05 PM
chris-jag's Avatar
Daim,
You Sir, are a star.
I would never have thought of that in a million years! :=)
Chris
BrentGardner
29
Dec 16, 2024 12:13 AM
hafren
Aug 30, 2023 03:42 PM
chipnping
Mar 8, 2016 10:33 PM
gene1
Sep 3, 2015 08:04 PM
plmmd
Aug 31, 2015 10:07 AM
