how do I want to adjust the tps on my 98 xjr?
Old Mar 16, 2015 | 11:56 AM
Muti007's Avatar
Default How do I want to adjust the tps on my 98 xjr?
While looking at some maintenance and ways to improve some odds and ends, I 've often come across the tip on adjusting the tps under the accelerator. I can't find exactly which way I should be adjusting it though. To maximize acceleration and speed up downshift, do I want to screw it clockwise to get it close to the ground as possible or unscrew it counterclockwise to bring it up closer to the accelerator? Tia
Old Mar 16, 2015 | 06:16 PM
Muti007's Avatar
Anyone? This adjustment is mentioned all of the time, can no one confirm how it should be done?
Old Mar 16, 2015 | 06:44 PM
Jhartz's Avatar
Leave it alone; you accomplished your objective by taking the slack out of the throttle cable.
Old Mar 16, 2015 | 06:45 PM
Muti007's Avatar
Ok, done. Thanks!
Old Mar 16, 2015 | 06:48 PM
RJ237's Avatar
TPS under the accelerator? If you mean under the pedal, that's the kickdown switch that causes the transmission to downshift under hard acceleration. If the transmission does downshift when the 'pedal is to the metal' it's working correctly. If not mess with it until it does, I have never had need to.
The TPS is part of the throttle body and is strictly hands off for us amateurs.
Old Mar 17, 2015 | 02:30 AM
plums's Avatar
The alternative for messing with the kickdown switch is to follow the procedure in
JTIS.
Old Mar 17, 2015 | 05:41 AM
grandell's Avatar
The only reason you would adjust your TPS is if you have had a throttle body rebuild and it needs calibrating. This is a one off job, and if you adjust in the future you risk inciting the dreaded limp home mode.
hoodun
May 25, 2020 09:08 AM
ogorir
Jan 18, 2016 10:09 PM
Col. Sandurz
Sep 28, 2015 12:49 PM
Samheath100
Sep 17, 2015 10:03 AM
Ipc838
Sep 13, 2015 03:27 PM
