how many miles does your XJ8 have.
Old Oct 28, 2012 | 11:48 AM
SuperSport's Avatar
Originally Posted by srteague
160,000 on my 2002 XJR.
Thinking of changing the fluid in the "lifetime sealed" tranny soon though.
I would highly recommend the Trani Service. I got an independent shop to do it for $130 using the correct fluid when I first bought it because I didn't know if the previous owner had ever done it.
Old Oct 28, 2012 | 04:23 PM
jjm01's Avatar
Default 77K miles
My 1999 XJR has 77K miles. Just replaced the fuel pumps for the second time.
Old Oct 29, 2012 | 01:38 AM
XJR-99's Avatar
What kind of fuel do you use? I mean ethanol %. Basically, if possible, our cars should use just eth free fuel.
Old Oct 29, 2012 | 09:31 AM
jjm01's Avatar
Default Gasahol
I avoid fuel with ethanol added wherever possible, but where I live it's all that's available in the winter months.
Old Oct 29, 2012 | 10:48 AM
Richy_Jsy's Avatar
Bought my Dec 2000 3.2 XJ8 in March this year with 120,000 on it. Now has 124,5xx and runs like a dream. Strong, quiet, comfortable,clean, admired everywhere I go. Well pleased. (Touching wood like mad- don't want to tempt fate!!)
Old Oct 29, 2012 | 01:50 PM
dja99's Avatar
Default 104k...
looking forward to doubling that!
Old Nov 1, 2012 | 08:54 PM
buckshaw's Avatar
2001 Vanden Plas Supercharged with 57k miles to date. Never any problems, love this car, it goes like stink!
Old Nov 4, 2012 | 03:42 PM
  #28
D. Fite's Avatar
My 2003 VDP has just over 64K. Runing great(KOW).
Dave
Old Nov 4, 2012 | 06:21 PM
hellfire127's Avatar
206,000 Miles.
Bought with 72,000 miles.
80k Timing chains
90K Front wheel Bearings
100k Front Ball joints, links, Front disks
110k Rear suspension renovate
120k Water Pump
150k Super Charger
160k Front Wheel Bearings (again)
190k Front Damper Bush, Balljoints
204k Gearbox
205k Front Wheel bearing (offside)
206k Alternator
Old Nov 5, 2012 | 12:04 AM
  #30
Tirefriar's Avatar
82,ooo miles on my '01 XJR. No nicasil and just replaced the timing chain secondary tensioners. Everything else works as it should. Fantastic car.
Old Nov 10, 2012 | 08:15 PM
  #31
maggiedozie's Avatar
1999 XJ8 has 97,000 original miles. It will go to the grave with me. Always had Caddys but this Jag is the absolute best. Getting an oil problem corrected and will make it better yet.
Old Nov 12, 2012 | 06:01 AM
  #32
Takeo's Avatar
Wink Miles ...
Hi,
my XJ8 (X308) from 2001 has now some 181.000 Km (approx. 112,500 miles) on the clock. Runs perfectly, very low fuel consumption.
5HP24 gearbox had 3 oil changes in last months to clear the system out.
Needs front and rear suspension bushes replaced now.
I love my Jag.
Takeo.
Old Nov 12, 2012 | 06:44 AM
  #33
Takeo's Avatar
Talking Tranny fluid
In the 60k since I've owned it:
Thermostat
S/C idler pulley bearing
Fuel pumps
(And I just did the plugs but that's a normal wear and tear thing)
Prior to me I know some coil packs were replaced.
Hi,
X308 auto tranny (5HP24) fluid: ONLY use LT 71141 ATF from Mobil. I buy it at abt. EUR 9,- per liter from a French website called LUBONLINE. Do not forget to drop the oil pan and change the filter.
Trick for emptying the box AND the torque converter:
* Put car on stands or elevator.
* Put large used oil tray under car.
* Drain oil via drain plug.
* Drop oil pan and remove filter. Discard filter.
* Put oil pan back on, provisionally.
* Undo top and bottom oil hoses from oil cooler.
* Tie both hoses, pointing downward as not to get engine front dirty.
* Start car and, on idle, with brake pedal well-depressed, cycle tru all gears, give every gear 3 seconds. Stop engine for 3 minutes. Do this 3 times. The torque converter will drain tru the hose of the oil cooler, (it will pump itself empty) mainly tru the bottom cooler hose, the cooler itself will also drain empty.
* Drop oil pan again, clean oil pan thoroughly, clean magnets inside oil pan.
* Let box leak out for 2 hours or so.
* Install new oil filter.
* Put oil pan back on, using a new seal.
* Do not forget to put drain plug back on but only tighten by hand
* Re-connect bottom hose to oil cooler.
* Using a VERY CLEAN or new hand-held piston oil pump with plastic hose, fill abt. 8 liters in gearbox, tru the top cooler hose.
* Re-install top cooler hose.
* Start engine, and with brakes held firm, cycle 3 times tru all gears.
* Go have a cup of tea.
* Check oil level via drain plug of oil pan. it should just drip out. If not, top up via drain plug hole, and tighten.
* Re-do the gear cycling process till proper level is attained, then tighten drain plug.
* Clean mess up you made under car.
* Have shower, cup of tea and go for test drive.
* Re-check level after about a 100 miles or so.
Note: gearbox oil capacity is 10 liters.
Good luck.
Takeo.
PS: I do not assume any responsibility for whatever I write.
Old Nov 12, 2012 | 08:48 AM
  #34
XJR-99's Avatar
XJR has Mercedes Benz 722.650 5-speed transmission.
Originally Posted by Takeo
Hi,
Good luck.
Takeo.
Old Nov 12, 2012 | 09:55 AM
  #35
sandy85's Avatar
Banned
120000km was running fine until i decided to change the gearbox oil
Old Nov 12, 2012 | 04:27 PM
  #36
onstar100's Avatar
'01 with over 197,000 km ( 122,400 miles). Running great. brakes, oil, ball joint & shocks. nothing unusual for 10+ years
Old Nov 14, 2012 | 07:09 PM
  #37
Red October's Avatar
2001 XJR with 149k-looking forward to the next 149k
Old Nov 17, 2012 | 10:33 AM
  #38
Zircon Blue XJR's Avatar
2002 with 104k, all ok apart from the standard trac /abs fault code
Old Nov 17, 2012 | 11:22 AM
  #39
richard thomas's Avatar
1998 XJR with 140,000 miles....ABS issue ongoing, rear axle just refurbished. Front axle yet to be rebushed, welding required at L/H V mount and some minor paint to do before I am happy....might even get the wheels refurbished, although I wish I had Asteroid alloys on it!
Lovin it! Goes like stink!
Old Nov 21, 2012 | 06:47 AM
  #40
danr's Avatar
132k on mine and purrs like a kitten :-) has got full servis history on it so hoping will go on forever.... so to speak
