how many miles does your XJ8 have.
Old Oct 11, 2024 | 08:52 AM
  #81
RandyS's Avatar
147,000 with no real issues.
Old Oct 11, 2024 | 09:33 AM
  #82
Addicted2boost's Avatar
Originally Posted by fransholland
Owing to the implementation of stricter environmental standards in the Netherlands, I am regrettably obliged to retire my faithful Jaguar from active service. I would like to express my sincere gratitude for its many years of dependable performance. Despite its considerable mileage, the vehicle remains good condition.
Can you not rebuild the engine and get new catalytic converters to meet emissions? I know diesels are a bit more controversial though.
Old Oct 11, 2024 | 10:41 AM
  #83
Hooli's Avatar
About 93k on my XJR, hardly run in really, but that's unlikely to change as it's taken 5 years to get that far from the 77k it had when I got it.
Old Oct 12, 2024 | 08:09 AM
  #84
Vauxi's Avatar
My R has around 173 000 km's.
Old Oct 12, 2024 | 06:57 PM
  #85
64etype's Avatar
My 2002 XJR had 38,000 when I bought it three years ago. It now has 40,200. I have replaced the headliner, both fuel pumps, the D/S heated O2 sensor, and all four shock donuts (In addition to all engine fluids). Seems like about 1000 of those miles has been running through the emissions system reset profiles. I'm paranoid about taking it more than 50 miles from the house.... I trust the old '64 E-type more. Sure looks pretty though.
Old Oct 14, 2024 | 10:10 AM
  #86
CvryanWRX's Avatar
Just rolled over 114,000 in my 2002 base model. I bought it 4 years ago with just over 100,000 and immediately did a trans fluid and filter swap. It's currently running rich and idling rough, so needs a bit more TLC but I believe the engine and trans will be strong beyond the useful life of the interior and plastic bits and bobs.
Old Nov 27, 2024 | 01:09 PM
  #87
Jag36's Avatar
My 2004 XJ8 has 205,000 miles and has been a daily driver in Arizona since new.  It still runs and drives like new, best car I've ever owned.  It's had 3 or 4 sets of running gear, 3 water pumps, new fuel pump, new radiator, 2 or 3 sets of mounts, many new hoses etc., etc. but the engine and transmission are still untouched. I replace worn out parts when needed and it's like new again every time.   Color Silver Patina
Interior still looks new, no squeaks no rattles nothing broken or missing, just solid.
Interior still looks great, no squeaks no rattles nothing broken or missing, just solid.
Old Dec 15, 2024 | 08:58 PM
  #88
jeff xj8's Avatar
[img alt="2002 the gold one, 10600 miles
2001 the silver one 1350000
"]https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/both_jags_2cb12d48d41ce9ce94b992329dbaf797792d2d37 .jpg[/img]
2002 the gold one, 10600 miles 2001 the silver one 1350000
Old Dec 16, 2024 | 07:56 AM
  #89
SOCONN13's Avatar
161,XXX miles on my 1999 XJR (Black on Black). I am the second owner, bought her in September of last year, with 149,XXX on the clock. Tensioners and a new transmission were replaced by her P/O. Think she did about 147,000 miles on the original timing chain setup, which is remarkable.
The car had been sitting (on a trickle charger) for about ten years when I took delivery. Since that time, I've replaced the tires, upper shock mounts, cupholder, marker lamps, PCV hose, battery, water pump, thermostat, coolant purge tank, spark plugs, coils (all of them simultaneously), cam covers, cam gaskets, every coolant hose including those in the dreaded valley, which led to the supercharger being serviced, power steering cooler, engine mounts, brake switch, front and rear shocks and bushings, and the drive belts/idler pulley.
Original engine, still pulls like a freight train. Regular oil changes at 5,000 miles, mostly dealer serviced until I found an independent shop willing to have lots of business from me. Knocking on wood that I'll have her for another 160,000+ miles, since it's worth functionally nothing on the open market at these miles, but is priceless to me.
Presently the only two things that need repairing are the sunroof (which operates but has the common issue of the shade that has come off the rails), and the nozzle for the windshield wiper fluid to the wiper. I have the part for the wiper, but have resolved never to fix the sunroof, as part of my philosophy that the second you make a used car absolutely perfect, it will crumble like a house of cards.
Old Dec 16, 2024 | 10:30 AM
  #90
RandyS's Avatar
Ha ha...In my mind...there is no such thing as absolutely perfect. However, it
surely could be a mindset one could acquire.
Old Dec 17, 2024 | 10:05 AM
  #91
jeff xj8's Avatar
i intended to attach this photo in my original message. i
Old Dec 17, 2024 | 12:26 PM
  #92
mayhem's Avatar
Currently 174,250 on my 2001 XJR as I rolled into the parking lot at work this morning, putting me at 50,000 miles since I bought it in July of 2022. Apart from significant problems with a rebuilt throttle body, its been very reliable.
Old Dec 23, 2024 | 09:21 PM
  #93
smgdata's Avatar
178,834 on my 2002 XJ8 and still goes like a bullet
Old Dec 24, 2024 | 01:44 AM
  #94
Hooli's Avatar
I'll update that, it ticked over 94k miles last week just before I filled up yet again.
No, I don't use it much but it is my only car.
Old Dec 24, 2024 | 10:26 AM
  #95
Winecountry's Avatar
My 2001 XJ8 VDP 40123.
Old Dec 25, 2024 | 06:56 AM
  #96
Elmo1544's Avatar
Default Finally Using It after 25 years
I bought mine new in `1999. Hardly used it for decades. Now with new shocks and tires etc. I use it every two or three days. Up to 44,000 miles. I am 78. I wonder which of us will make it to 100... first!
Old Dec 25, 2024 | 03:35 PM
  #97
socal1200r's Avatar
That silver car in AZ is in remarkable shape for having over 200K miles! From this and other posts, it's good to read that these cars can actually go over 100K miles without catastrophic maintenance costs.
Old Dec 27, 2024 | 02:27 PM
  #98
cat_as_trophy's Avatar
Originally Posted by socal1200r
. . . it's good to read that these cars can actually go over 100K miles without catastrophic maintenance costs.
Based on my 55 years of running a tribe of Jaguars, I respectfully offer an alternate view . . . it is the well travelled and well maintained Jaguar that avoids any cat-as-trophy, whereas the 20yr laid up barn find has far more chance of rendering the luckless new owner penniless overnight. The message for me is clear . . . use it; maintain it; love it; and its superb engineering will reward you . . . but, ignored or mistreated, it will make you pay!
The Mk1 in my avatar reminds me constantly. Flattened by a fallen tree in a violent Blue Mountains snowstorm, it was rebuilt from the ground up at 100,000 miles. Crankshaft was as brand new, with all journals and big ends within factory tolerances. Bored and rebuilt with straight port head, hot cams, twin straight-through exhaust, this Jag ran for another 250,000 miles under my ownership with no expenses other than lubes, tyres, battery etc. By comparison, a Series II E-Type with only 7,000 miles, suffered what could have been a tragic end when a rear brake line ruptured during its first drive after being "fully checked over and polished up".
Cheers,
Old Dec 27, 2024 | 02:28 PM
  #99
Jhartz's Avatar
Old Dec 30, 2024 | 04:07 AM
  #100
dmg4's Avatar
2003 XJ8 with 74,000 on the odometer: a new purchase for me, a first-time Jaguar owner. Looking forward to Spring, Summer and Fall.
alex muller
Nov 2, 2023 11:04 AM
pcolapacker
Jul 22, 2022 09:00 PM
