I smell burned oil when I stop at a stop sign and when I turn the Jag off
Old Jul 12, 2020 | 06:19 PM
Steve W's Avatar
Default I smell burned oil when I stop at a stop sign and when I turn the Jag off
It's an 02 XJR. Does that mean there's a leak somewhere? There is no oil on the garage floor.
Old Jul 12, 2020 | 07:29 PM
avern1's Avatar
The most likely culprit is the cam cover gasket near the rear of the engine leaking and dripping oil on the catalytic converter.
Old Jul 12, 2020 | 07:40 PM
Highhorse's Avatar
+1....also, be sure to check the breather tube between the cam cover and the air filter for blockage. If its built up enough, it can smell.
Old Jul 12, 2020 | 08:06 PM
vincent661983's Avatar
Almost always the valve gasket
Old Jul 12, 2020 | 09:09 PM
Addicted2boost's Avatar
I believe this is what highorse more or less was referring to. It’s located on the same side as the oil filler cap. The part load breather is the side that can get clogged up so bad that I’ve seen air filters soaked with engine oil because the PL breather was nonfunctional and it would get sucked out thru the full load breather going from the valve cover to the air intake tube when it’s supposed to be flowing out of the PL breather. A clogged PL breather will also cause excessive pressure inside the engine and cause oil leaks.
https://www.jaguarforums.com/forum/a...e-breather.pdf
Old Jul 14, 2020 | 03:27 AM
Steve W's Avatar
I found out the valve cover gaskets are leaking so they are getting replaced.
Old Jul 14, 2020 | 11:58 AM
from my (bad)experience, is always on the left side
also make sure if you need to replace the bolt and nuts
Old Jul 14, 2020 | 01:51 PM
avern1's Avatar
The left is usually first to leak because as Highhorse said the Part Load Breather plugs and causes crankcase pressure in the cam cover. Unless you find the cam cover cracked, the most likely cause of the leak is the breather.
Dannyaspect34
Oct 11, 2022 03:50 PM
Davidvdm
Oct 7, 2015 03:18 PM
jjbanks
Mar 7, 2015 09:17 AM
BrentGardner
Oct 11, 2013 03:53 PM
chrystalcook
Aug 25, 2013 08:54 AM
