I washed the jag key
Old Mar 5, 2018 | 12:38 PM
Jaguarstyper's Avatar
Originally Posted by Sean B
Based on what I hear and see, number one check is battery voltage - what is your car's battery showing (have you a multimeter?)
Number 2 - the key module housing is glass, that sounds like it's broken. Have you any mobile locksmiths, specializing in cars locally? A forum member recently posted a brilliant service that pulled the chip's code and cloned it onto a blank then cut the blank, I'll see if I can find it as it may be of help.
https://www.jaguarforums.com/forum/x...locked-195622/
Personally I think the key's module is trashed for starting the car, it's shouldn't ring like in your video. It can still be used for trunk, glovebox and drivers door though.
The dealer should be able to pull the key code and supply a new key but you'll need to be sat down when they hand you the invoice.
Yes, it does unlock the doors though I have left them unlocked since I'm not taking any chances, last time I was at the dealer for my other jag a s type they didnt have any ford keys so I'm going to call them and order one, in the meantime I have found a spare for my ford truck so I guess that will do for now
Old Mar 5, 2018 | 12:40 PM
Also in the video the door was open
Old Mar 5, 2018 | 07:28 PM
Highhorse's Avatar
I give Sean a +1 on that rattle...it does sound like the case has been compromised.
sthames42
Mar 19, 2014 03:57 PM
swaite3
Nov 2, 2013 06:34 PM
Selsoft
Jul 5, 2013 09:51 AM
rosemont83
Sep 11, 2008 03:18 AM
michaelnv
May 30, 2007 02:46 PM
