Idle off.
Old Aug 29, 2017 | 08:57 PM
omgimali's Avatar
Thanks guys. Car doesn't sit, its a weekly driver. and what should my stft and ltft should be between?
Old Aug 29, 2017 | 09:35 PM
ericjansen's Avatar
Your readings should be within some +/- 5 along most of the RPM range, although you will see short higher values during de- / accelerating and other load changes.
A well balanced car should have LTFT's within some 3 points around the zero.
Old Aug 30, 2017 | 07:51 PM
omgimali's Avatar
would a bad fuel filter be changing the fuel trims. and can a bad maf sensor change fuel trims?
Old Aug 31, 2017 | 01:38 AM
JagV8's Avatar
Yes to both.
