ignition coil 3, circuit c misfire
Old Apr 21, 2011 | 08:35 PM
matyx's Avatar
Default ignition coil 3, circuit c misfire
does anyone know which cylinder is number 3 on a 2003 jaguar xj8? Anyone have a diagram?
Old Apr 22, 2011 | 06:56 AM
sparkenzap's Avatar
matyx:
The chart has been posted several times. If you cannot find it in the archives, post back and someone will help find it. With only one digit in your cylinder number, you must be refering to the OBDII designator, which is 1 through 8, with 3 correseponding to the Jaguar cylinder number A-3, which is third back on the right hand (US passenger) side.
Old Apr 22, 2011 | 08:58 AM
test point's Avatar
You will find the chart in the XK8/R forum FAQ Sticky. It has been modified from the JTIS charts to display the OBDII code identification.
https://www.jaguarforums.com/forum/x...ts-data-29800/
pnwrs2000
Nov 17, 2015 04:04 AM
sunchip
Oct 5, 2015 02:05 PM
Bcrary3
Sep 27, 2015 12:21 PM
reb1999
Sep 26, 2015 08:41 AM
