This an ignition coil symptom?
Subscribe
Nov 16, 2014 | 09:55 AM
2001 XJR, drives great. Park the car, turn off and take the key out of the ignition, and various random lights on the dash light up, some brighter than others, high beam etc, various random warning messages show up. After a while it seems to settle down and just display the odometer, then finally turn off. Coils? Alternator? Battery?
Thanks in advance,
ZIg
Reply 0
Nov 17, 2014 | 04:00 AM
Battery or wiring fault.
Reply 0
Nov 17, 2014 | 08:37 AM
Thanks JagV8
Will load test the battery tonight... hedging towards that.
Reply 0
Nov 17, 2014 | 08:59 AM
My wild guess would be that some relay is sticking for too long before letting it go (with the turn of the key most of periphery is cut off while main computer is still monitoring for a few seconds...).
Reply 0
Nov 17, 2014 | 09:01 AM
I assume you are aware of the X-300 flashing dash / ignition coil correlation and therefore the question. However, that happens when the car is running and the ignition is making high voltage pulses that are causing noise in the dash circuit.
You might have a look for the TSB recently posted by motorcarman that describes a solder migration problem in the instrument panel.
Reply 1
Nov 17, 2014 | 08:43 PM
I posted that TSB for the CAN bus fault but I did not realize that the poster had a CAN bus fault that was 'self-inflicted'. The cause was an OBDII devise??
bob gauff
Reply 0
Nov 19, 2014 | 07:26 PM
bob:
I am not sure... It sounded like that might have been it.
Reply 0
Subscribe
Currently Active Users (1)
