Ignition coils
Old Sep 30, 2016 | 04:18 PM
Daim's Avatar
Default Ignition coils
Hi there,
Are the ignition coils interchangeable? Sounds weird but can I use later 2 pin versions on my 2 pin coil cat? Jaguar says that there are two numbers: Either LCA1510AB or XR827823
The only note is to VIN F00034 for the first, and from F00035 for the latter.
Can Imuse the earlier on a later or a later on an earlier car?
Damien
Old Sep 30, 2016 | 09:22 PM
Highhorse's Avatar
IMO, there is a reason they specify such for the VIN's, it can be because of the ECM or the wiring detail or a change in EPROM, it can be a number of things. To err on the side of caution never hurts.
But I also reference such things, so I will simply do a Bing search using the part number and see what prevails. Many times a link will come up showing a thread or threads on sites regarding the item. I also use this site... https://frugalmechanic.com/ ...to see what comes up. As time goes by manufactures may find a common build type that allows for use on both VIN's, but always check before applying (like you are doing now..) and check the date of the post.
Old Oct 1, 2016 | 03:33 AM
xjay8's Avatar
Originally Posted by Daim
Hi there,
Can I use the earlier on a later or a later on an earlier car?
Damien
There should be no reason why 2 pin to 2 pin cannot be transposed.
The big difference came with the 4 pin coils as used on AJ27 engines.
At least that is how I view it ;o)
Uncle Fishbits
Sep 18, 2016 01:01 PM
Jaguar Forums Editor
Jaguar Press release
Sep 8, 2016 04:28 PM
RonaldP
Sep 8, 2016 08:58 AM
Sep 7, 2016 04:48 PM
