Ignition Switch Problems
Old Nov 28, 2014 | 07:55 PM
PAJ's Avatar
PAJ
Default Ignition Switch Problems
I have a 1998 Jaguar XJ8. Recently turning the key while in the ignition switch becomes hard to turn. Now is takes quite a bit of effort and sometimes pushing down on the steering wheel helps.
Has anyone else had an issue like this? The key goes in but will not turn completely to start the car,
Thanks,
Old Nov 28, 2014 | 09:42 PM
avt007's Avatar
It's not that hard to get the ignition barrel out of the steering column. Maybe then you can clean and lube it, maybe spot what the problem is.
Old Nov 28, 2014 | 10:08 PM
Sir Jagness's Avatar
I have used fine powdered graphite to free up sticking locks. Obtainable at locksmiths or larger hardware stores.
Old Nov 29, 2014 | 03:28 PM
Hi ho PAJ,
Assuming there are not mechanical issues with your lock, the reason I suggest fine powdered graphite to free up stuck locks, is that graphite does not attract and hold dirt and dust, as in petroleum lubricants. Over time, the petroleum lubes will actually gum-up lock tumblers with the attracted dirt.
Other lubricants such as Tri-flow or Silicone based lubes do not attract dirt or dust as well, and will successfully free up locked tumblers too.
Old Nov 29, 2014 | 07:40 PM
PAJ's Avatar
PAJ
Thanks for the responses. This happen once before, but cleared up after short time. I will give the graphite lube a try.
Forcedair1
Sep 8, 2025 01:57 PM
JarodL
Mar 7, 2024 01:39 AM
XJsc-guy
Nov 23, 2015 01:56 PM
arnoldmilk
Sep 3, 2015 07:42 PM
laserguy
Sep 3, 2015 02:02 PM
