Im sure this has been covered already...
Old Jul 27, 2016 | 10:21 AM
Volganity's Avatar
Unhappy Im sure this has been covered already...
Bought a 2000 xj8 about 6 months ago. 100,000 miles. First two months went great. Then my throttle position sensor went out so I replaced it. In the meantime the abs unavailable, Trac unavailable, and gearbox fault lights have all came and went. Remove battery cable and it was good for a week or so. Tried to start it yesterday and it refuses to. Undone the battery cable like I usually would in this case and left it off for about 30 minutes, tried to start again and still nothing. The car runs great when it wants to start. Transmission shifts great. No loss of power. Just had a full tune up about a week ago. So if anyone on here can help me out with what could possibly be causing the messages to show and why it won't start I would greatly appreciate it.
Old Jul 27, 2016 | 02:00 PM
King Charles's Avatar
Start with a new battery, then pull codes.
Old Jul 27, 2016 | 06:59 PM
Vector's Avatar
Need more info.
Does the starter work?
Does it turn over but not start?
Or not turn over at all?
Could be a bad battery, bad grounds or other connections, inertia (impact) sensor, fuel pump, etc., +100.
As was said, get it running, if you can, and pull some codes.
Vector
Old Jul 28, 2016 | 07:03 AM
LeLimoMan's Avatar
Definitely sounds like these cars require a good, strong battery. Most auto parts store testing is insufficient and can give a false sense of the true condition of the battery. I just bought an '03 XJ8 with 100K and while I'm not having these issues (yet), I'm going to replace the battery ASAP.
Can anyone tell me the locations of all the critical ground connections on these beasts? Long time British car owner and I know how important they are and all the gremlins they cause if not good and solid.
Thanks for the help!
Old Aug 1, 2016 | 01:11 AM
Volganity's Avatar
Stared works. Turns over but doesn't want to start. Pulled the codes and changed throttle position sensor. But still same problems. Going to try a new battery and see if that fixes it. Thanks
Old Aug 1, 2016 | 02:06 PM
Vector's Avatar
STOP! You are chasing the problem by throwing parts (and $) at it.
Please post the codes you have pulled here!
Do not depend on the local auto parts store or the internet to correctly interpret the codes for your jag.
Give us the info we need and let us help you.
Vector
Old Aug 1, 2016 | 02:09 PM
Vector's Avatar
Download the manual for your car from the "sticky" section at the top of the x308 forum page. All your ground points will be listed in the manual.
Vector
Apr 17, 2019 04:33 PM
Sep 1, 2016 05:54 PM
Michael Wittmann
Mar 29, 2016 05:16 PM
Michael Wittmann
Mar 27, 2016 07:45 PM
Nov 21, 2005 05:05 PM
