increased engine noise
Old Mar 11, 2015 | 11:43 AM
wcourt3010's Avatar
Default increased engine noise
Hi, I've noticed recently that my engine has this buzzing or droning sound when I'm travelling at low speeds with the accelerator barely depressed, around 25 MPH / 1500 - 2000 RPM. I turned the climate control off and the noise is still there. It goes away when i accelerate or come to a stop and just idle. first time i heard it i thought it was a ww2 bomber flying overhead, very noticeable.
car is a 1998 XJ8 VDP with 177K kilometres on it, just had the timing chain tensoner issue fixed. oil and coolant levels are fine.
this droning sound does not impede the performance of the car in anyway. The engine temperature seems fine. At Idle with the hood up there is no noticeable noise. Seems to be coming from the engine but can't rule out the gear box. any thoughts?
Old Mar 11, 2015 | 02:39 PM
Morpheus311's Avatar
I'm dealing with similar problem now. Mine is front wheel bearing is worn and needs to be replaced.
Old Mar 11, 2015 | 07:27 PM
JimmyL's Avatar
I had a wheel bearing going that sounded like a helicopter was flying overhead. Can you hear it when the car is stopped ? Are you sure it was a bomber it sounded like? ;^)
toronadomike
Jan 22, 2026 10:13 PM
Wolfy
May 28, 2024 08:06 AM
robiwhan
Sep 4, 2015 10:43 AM
OkieTim
Sep 2, 2015 12:48 PM
innzane
Sep 2, 2015 10:08 AM
