Indicator audio signal
Old Oct 24, 2018 | 03:34 AM
Jeroen's Avatar
Default Indicator audio signal
My 2002 XJR is suffering from an annoying little problem. When I turn on the indicators (right or left) sometimes the indicator audio signal comes at double the frequency. Normally this would indicate a broken bulb. But everything on the outside is working perfectly normal.
No error code. I have cleaned every ground connection. I have taken all the indicators apart, cleaned them, tried different bulbs. I checked every connector in the circuit. I have checked the wiring as much as I can. Visually for any chaffing and for continuity/shorts.
I had the BPM out, checked the connectors, opened it up and inspected the PCB, soldering and components.
It is intermittent too. About 50% of the time, both right and left.
Apart from some sort of problem with the BPM itself, anybody any suggestions what else I could try/check?
Jeroen
Old Oct 25, 2018 | 12:08 AM
nilanium's Avatar
Maybe something with the turn signal lever/switch or related wiring, esp the steering wheel cassette cable? The problem sounds like continuity somewhere, maybe an internal BPM fault where it's getting a false reading on turn signal bulb impedance.
Jens boy
Nov 20, 2015 06:10 PM
EFlavio
Jun 5, 2013 04:22 AM
studebakersui
33
May 11, 2012 03:55 PM
Waterwalker
XJ40 ( XJ81 )
Mar 17, 2009 06:43 PM
studebakersui
General Tech Help
Dec 3, 2008 01:54 PM
