Inspection of secondary chain tensioners
Old May 4, 2010 | 07:45 AM
rocklandjag's Avatar
Default Inspection of secondary chain tensioners
I recently bought an '01 VDP SC with 80K miles on it. Having read so much about the chain tensioners I wanted to what kind of shape mine were in or if they had been changed out and gauge how quickly I need to replace the tensioners.
I pulled the right side valve cover and everything looks very clean. The top of the valve cover is clean as are the cams and the head. As best I can see there is little wear on the tensioner on this side. I used a mirror to look below the tensioner and between the chain and the side of the tensioner.
I am wondering if the cracks in the body of the tensioner that I have seen posted are on the piston side and can not be seen in the attached photos
If your look at the mirror in some of the photos you can see the bottom and side of the tensioner as well the top
Ed
Old May 4, 2010 | 08:04 AM
Brutal's Avatar
those are old style, replace em. while they look great and the previous owner changed oil properly for driving conditions. youre half way there. Buy new ones and shorter bolts, and change them out. Leaving them in is like driving without a seatbelt
Old May 4, 2010 | 09:40 AM
test point's Avatar
They don't fail slowly!
Old Oct 15, 2012 | 08:22 AM
JimmyL's Avatar
Talking Cam Chain Tensioner
Well, attached is a picture of one of my old ones. It's hard to tell from your photos, or I'm just getting more myopic. But, I agree, change 'em.
Attached Thumbnails Inspection of secondary chain tensioners-camchaintensioner.jpg
Old Oct 15, 2012 | 09:10 AM
Sean B's Avatar
and here's one just about to go....a replacement engine job will run $5k...
Old Oct 15, 2012 | 01:22 PM
coastaljag98's Avatar
mine looked like that at 192K miles. ORiginal and owners treated my Cat badly. Its a wonder they didn't fail...it just knew it was coming to a good home! Easy job -- do the zip tie method and you'll be in an out of there in an hour tops.
Old Oct 18, 2012 | 09:14 PM
aleop's Avatar
coastaljag98,
What is the zip tie method of renewing the chain tighteners?
Aleop
Old Oct 18, 2012 | 10:03 PM
cleric61's Avatar
Smile Zip tie?
I would also like to know how to do this. If it really is that easy.......I will do it ASAP. Where do I get the replacement tensioners?
Thanks in advance for any info.
Old Oct 20, 2012 | 11:00 AM
Tirefriar's Avatar
I hate to polute forums with double postings but saw this thread after posting in a previous one. Anyhow, I have an '01 XJR. No nikasil but most likely plastic tensioners. I absolutely love this car and plan to hold onto it for a long time. How much should a retrofit cost?. I work on my Alfas, but mainly light body and mechanical ( remove/replace). I'd like to have a pro do this so that I can sleep good at night. Any recommendations on a great tech in San Fernando Valley/los Angeles area? Thanks in advance
Old Oct 20, 2012 | 02:01 PM
Sean B's Avatar
@Tirefriar - If you wrench search for 'the zip-tie method' or 'I did my own tensioners', you can be in an out in a few hours and save a bundle including the special tools.
Quotes +- $1000 inc parts.
Old Oct 20, 2012 | 02:13 PM
dsnyder586's Avatar
Hey Tire,
I owned three Spiders- 1971, 1973 1986 Quad Loved those cars.
Definitely change them out- shouldn't take more than a couple hours with the zip tie method.
If you can change the cam timing on an Alfa, you can do the zip tie method.
Old Oct 20, 2012 | 02:46 PM
Sean B's Avatar
My old man is an dyed in the wool Alfisti, he owned a rash of them when I was a youth, the 105 series after using a Lotus Cortina MK1.
Gt Juniors, 1300 GTC, 1600 1750 and 2000, a couple of 'Italian Job' Julia Super's and the best of the bunch a genuine Auto-Delta Berlina 2000. I remember some drives in that car, built to drift all four wheels
Old Oct 21, 2012 | 09:25 AM
aleop's Avatar
I am fairly new to this site and don't know what you mean "wrench search,zip-tie method" Tried entering this under search and got nothing. I thank you in advance,Trirefriar.
Old Oct 21, 2012 | 09:46 AM
WaterDragon's Avatar
Where is the best place to buy the parts needed to change the tensioners?
BOTH my 2002 XJs need it. Even though the vin # and engine # says my XJ8 was made well after the change over, I pulled a valve cover yesterday just to check, and saw the plastic tensioners.
Other than pulling a valve cover, there is no way to be sure with a 2002.
Old Oct 21, 2012 | 10:03 AM
Sean B's Avatar
I'll be crystal clear,
if you use wrenches to fix your cars, then you will be able to do this job.
To search on here for probably the most common job undertaken on this model of Jaguar, search for the following terms
'zip+tie+method'
'secondary tensioners'
'timing chain tensioners'
etc etc etc...
(posts on this forum are almost daily on secondary tensioner exchange...)
Hop this is clear and assists
Old Oct 21, 2012 | 01:33 PM
RJ237's Avatar
WaterDragon,
I used sunroadfordparts.com and ordered parts for a 2001 Lincoln LS.
2W9Z6K254BA
2W9Z6K254CA
and 4 bolts W500301S300
The gasket set for the AJ27 engine is available at one of your local automotive supply stores, although Sunroad probably has them also. Get the FelPro set, I understand they are better quality. My car has the AJ26 engine, so I had to buy Jaguar gaskets.
RJ___________
97 XK8 86K mi
96 XJ6 120K mi
mikiep
Dec 20, 2019 07:37 PM
Msteiner
May 16, 2016 12:19 AM
redxk8
Oct 4, 2015 08:28 AM
inactualis
Oct 2, 2015 11:13 AM
millertic
Sep 30, 2015 08:11 PM
