Intercooler pump wiring loom socket blanked off at factory?
Old Jun 10, 2019 | 12:04 AM
henry crun's Avatar
Default Intercooler pump wiring loom socket blanked off at factory?
I recently discovered that the inter-cooler pump on my 98 Super V8 was unplugged from its power supply socket and its socket was instead plugged with a blue coloured plastic blank! I can't think of any other explanation except that my pump had NEVER been plugged in since car assembly. Surprisingly, my cars ECU has never recorded a P1113 code (high air-intake temp from IAT2 sensor).
Consequent pump connection yielded a subjective improvement in throttle response/horsepower and an objective 8% improvement in fuel economy, which is not surprising given its previous inefficiency of passing intake air though a heat soaked inter-cooler (i.e. inter-heater) even when not on boost.
Does anyone have an alternative explanation for why my loom socket would be blanked off?
I assume that my car is the exception, but it might be worth confirming that your own cars inter-cooler pump is connected. Its easy to check - both inter coolers should be considerably cooler to touch than the supercharger & engine after driving. You should also hear the pump running (under hood with ignition on & engine off). The pump wiring connection is a small 2 wire D plug & socket which is attached to the underside of the front right hand side (facing forward) chassis rail.
Old Jun 10, 2019 | 08:15 AM
Sean B's Avatar
that's super weird!
xxxscimitarxxx
Sep 10, 2020 11:13 AM
taxman
Aug 2, 2017 09:41 AM
Sapphire Blue
Jul 3, 2017 02:46 AM
Portfoliolio
Feb 16, 2015 04:02 PM
SteveM
Oct 12, 2010 09:57 AM
